all thread rods?
all thread rods?
I posted yesterday about bit stripped balancer threads and a hub installer... From what I got the best way to get the hub on the crank is to thread in a all thread rod and use a washer/bearing and a nut to push it onto the crank. As of right now i've pretty much called or been to every single place in this area (and I live in the suburbs of chicago, so thats a lot of places) and the only thing I have found in threaded rods is a 7/16-14 rod (course threads). Absolutely no one carries a 7/16-20 (fine thread) rod. (to come to think of it I couldn't find any size threaded rod in a fine thread)...
Is there somewhere online I might be able to buy one of these threaded rods in this size? I'd be willing to wait a bit to get it through shipping if anyone can find one of these, because I haven't had to much luck with trying to find somewhere that would ship out just one threaded rod in that size.. Anyone know for sure if they even make it?
Re: all thread rods?
All thread would be nice, but you don't neeeeed it, just get a longer bolt! It will be much easier to find a longer bolt than the correct thread allthread rod.
If the bolt you get is too long that the threads will bottom out in the crank, just add spacers. You just need the longer bolt (or allthread) to get the balancer started, then the stock bolt will have enough thread engagement.
I know this didn't directly answer the question you posted, but I think your going to spend a lot of time searching for the allthread you don't need.
If you really feel you need it, try mcmaster carr, mscdirect.com, and grainger; they are the big 3 industrial suppliers and would be the first place i'd look. The longer bolt from my local hardware store worked fine....
Good luck,
Brent
Good luck,
Brent
Good luck,
Brent
Good luck,
Brent
What exactly do use to cut down a steel rod like this?.... Will a grinding wheel work?
A harmonic balancer installation tool works really well. I just put my hub on tonight and it was much better than the threaded rod, especially since it has a bearing that comes with it for the nut to ride on. Free rental from Auto Zone. I did have to buy some washers to get the nut out far enough from the inside of the hub to get a wrench on it.
Oh yeah, Fastenal can get the threaded rod too. Part 47672.
http://www.fastenal.com/web/products...l.ex?sku=47672
Looks like there's several of them in the Chicago area. That's where I bought mine at (and then ended up not using it).
It's a really bad idea to use a bolt of any length to pull the hub on. If you want to risk your crank threads, then go ahead.
If you use an all thread rod, get one that is at least grade 8 (with accompanying nut).
http://www.sallee-chevrolet.com/Tools/images/61741.jpg
How exactly did you make this work for you???
That's pretty much the same tool I used. Maybe the one I used had a longer piece to make it to the crank. I actually did take pictures last night but they're on my camera at home, I'll try and get them this evening.
Just keep in mind that these kits still only have about 1/2" - 3/4" of thread that goes into the crank. It worked okay for me, but I was installing a new ATI hub that was just honed onto a new crank, so it went on without excessive force.
Catmaigne
Jul 14, 2015 05:17 PM
