View Poll Results: How Has Your Rear End Held Up?
Automatic, Drag Radials------No Problems
15
25.86%
Automatic, Drag Radials------Broke it
3.45%
Automatic, ET STREETS------No Problems
11
18.97%
Automatic, ET STREETS------Broke it
3.45%
Manual, Drag Radials------No Problems
13
22.41%
Manual, Drag Radials------Broke it
6.90%
Manual, ET STREETS------No Problems
8.62%
Manual, ET STREETS------Broke it
10.34%
Voters: 58. You may not vote on this poll
All Running ET STREETS & DRAG RADIALS! (Valuable Poll To All)
Old Mar 12, 2004 | 12:07 AM
96redformula7's Avatar
I will be running ET Streets on my car tommorro, if not them Sunday. I hear you are going to break it, it will be fine. Let's take a poll of how many people with an AUTOMATIC or a MANUAL have had their rearends LAST or BREAK.
I am running 2800 Vigilante stall, 3.73 Gears & DTS Girdle by the way.
Notice their will be an option for Automatic & Manual (ET Streets or Drag Radials)!!!!!
Old Mar 12, 2004 | 12:24 AM
GhostZ's Avatar
Auto + 3200 + ET Drags + 1.6's =
Oops....did I check ET Drags or Streets? Either way...it held up on countless 1.8 launches but after a night of 1.6-1.7's it went to the happy rear end heaven in the sky.
Old Mar 12, 2004 | 01:07 AM
Kain's Avatar
Auto + ET Streets. Haven't had any problems yet, but I'm in the low 1.6 (maybe and hopefully high 1.5) 60' breakage zone.
When your wheels start getting hang time, all the weight is on the rear axle and its really hard on it.
Although I've seen a 3.42 rear 10 bolt with a T/A stud girdle handle a season full of 1.5 60's and a best of a 1.48 60'.
Old Mar 12, 2004 | 01:31 AM
a walker's Avatar
Broke mine 3 times.
1st time was on the street. Stock trans and convertor, no spray. Broke my Richmond 3.73 gears (something like 10 teeth off the ring gear and 3 off the pinion).
2nd time was at the track with the FLP trans and convertor in my sig, no spray. Ran a 1.8 60'. It went a little after the 60'. Broke my Richmond 4.10 gears I think it was 26 teeth off the ring gear and 6 off the pinion).
3rd time was on the street, no spray. Broke the output shaft in my FLP trans on the 1-2 shift.
Old Mar 12, 2004 | 01:41 AM
So 2 out of the 3 times you broke them on the Street??? You drive on the street with ET STREETS???
Old Mar 12, 2004 | 02:37 AM
a walker's Avatar
Yep, broke em on the street. I occasionally ran them on the street on the weekend. Not too far from home or anything, but just to cruise nights or car shows or if I thought there was going to be some racing going on.
BTW, when I run them on the street, they're always at 28 psi, I never drop them down except at the track.
Old Mar 12, 2004 | 05:00 AM
RacinLT1's Avatar
i broke a set of Gm Motive 3.73's with drag radials on the track with a stock stall.
i broke the output shaft/planetary/pump of my auto on hoosier quick time pro's.
Old Mar 12, 2004 | 05:23 AM
IllusionalTA's Avatar
I only launched on Et Street's and a STock rear once.. It lived.. But i did break my output shaft on 275/40 nitto's.. So it could break either way... Go out and have fun...
Old Mar 12, 2004 | 06:09 AM
funina91ss's Avatar
Auto 3,200 stall 3.23 gear best 60ft is a 1.54 most are 1.60 I run a Solid Pinion Bearing Spacer Seems to help out more than anything else you can do to a 10 bolt.
Old Mar 12, 2004 | 06:36 AM
FASTFATBOY's Avatar
I broke my stock 10 bolts spider gears at the track on 275/40/17 Futura ultra Z's, BOOM.
David
Old Mar 12, 2004 | 06:53 AM
93ZM6Tally's Avatar
Additonal category:
Manual ET Streets - 12 Bolt, No problems no worries, 6k launches.
Old Mar 12, 2004 | 07:48 AM
FastZinTennessee's Avatar
I ran ET streets one night at the track, made three passes no problem on stock stall. Last year I used to daily drive BFG drag radials and made quite a few passes at the track- no prob- 2800 stall.
Old Mar 12, 2004 | 08:15 AM
T/A lt1's Avatar
Auto, have had ET streets, ET drags and no problems. I have run a number of 1.5 60's on n2o and making 500rwhp! I was making 400+rwhp on motor + a 150shot and had no problems although the car always spins so that may be part of the life of my 10bolt. I use only GM gears too. If you plan on keeping your 10bolt my suggestion would be run it until it breaks then put a set of GM 3.23's or 3.42's and a good posi and you will be fine. I saw first hand a LS1 car run 9.90@136mph on the stock 10bolt with 3.23's .
Old Mar 12, 2004 | 08:38 AM
Fastbird93's Avatar
I was running my black car on Nitto's, and funny part is that I never bested my all time low short time on street tires. Never even came close with the Nitto's actually. Best I've gotten off the line with Nitto's is a 1.96.
However, to be fair, I'm now running a street twin, and I don't forsee a long life on anything.
Old Mar 12, 2004 | 09:15 AM
You all are Great , keep the poll and the posts going. See, I told you all this is a very valuable poll to all.
