Are all M6's the same?
Old Apr 23, 2003 | 07:17 AM
Mr. T's Z's Avatar
I am building my buddy's 94 Z28 for him. His M6 is toast. I can get one out of a wrecked 00 SS. Are they the same bolt pattern etc and all the plugs the same?
Thanks,
Tyler
Old Apr 23, 2003 | 07:20 AM
Dave 96TA's Avatar
AFAIK this wont work because the slave system is setup different...it is internal I believe, as opposed to the 93-97 external slave cylinder.
Old Apr 23, 2003 | 08:24 AM
philcam01's Avatar
like Dave said it would have to be from a 93-97 unless you also want to change the input shaft.
Old Apr 23, 2003 | 10:19 AM
Mike94ZLT1's Avatar
Dont forget 2 different versions were offered in 93, the M28 and the M29, and both are different from the 94-97 T56. 93's have higher gearing, ie. should be faster BUT have a lower torque handling capacity. I believe its 400 ft/lbs as opposed to 450 ft/lbs.
Old Apr 23, 2003 | 12:28 PM
Tommy'Z 6speed's Avatar
As stated, the 98 + cars use an internal slave hub type actuator (it acts directly on the release bearing) and the LT1 cars used a conventional slave cylinder with an actuating fork.
The end plate (piece that the shafts mount to) is different between the 2 types.
I didn't know that the input shafts were different.
