Are all LT1 intakes the same?
Old Jun 12, 2003 | 10:37 AM
  #16
KCFormula's Avatar
Originally posted by GUMP
The 92-93 intakes do not have provisions for the fuel cross over at the front of the fuel rails like the later manifolds.
There are also two different 94-97 intake designs. The ports are much different on the later intakes.
Daren
YUP.
Old Jun 12, 2003 | 10:52 AM
  #17
Laymaster's Avatar
93 has to be different because in 94-97 the oil pressure sensor is on the back of the intake manifold...
Old Jun 12, 2003 | 11:42 AM
  #18
anaik's Avatar
It screws into the block, not the intake.
Old Jun 12, 2003 | 01:08 PM
  #19
DiabloZ's Avatar
Exactly.. I can't beleive how many people think the Oil pressure sending unit is in the intake. Just think about it ..how could you get a reading on oil pressure from the intake when there are no oil passages and no oil in the intake??? It's in the block behind the intake and has nothing to do with the intake design.
Old Jun 12, 2003 | 02:42 PM
  #20
poloz28's Avatar
ok so i have posted the casting number from the passenger side, my fuel rail crossover is in the front and i KNOW FOR A FACT that my oil pressure sending unit is behind this intake and my engines intake. so will what i have fit on my 1994? and will there be any adverse affects?
PB
Old Jun 13, 2003 | 08:37 PM
  #21
arnie's Avatar
The early intakes have symetrical ports, the later ones do not.
Daren
I gotta agree with Daren. The later intakes more closely (improved) match up to the port shape in the LT1 heads. The original LT1 head/intake matchup was a screwup. It wasn't their first, and don't expect it to be their last. I find it a mild surprice they actually allocated the funds for the change. But then again, the change was about the time the LT4 intake cast was made. (The later LT1 intake is a whole lot closer to the LT4 intake than many realize). My guess is, they (GM) would not have bothered with the change had the LT4 intake not become a reality.
Originally posted by turbo_Z
.. differences between the 2 are unknown to me but i have looked into this and people told me they are the same. i sure as fck hope they are the same!! i put a 95 intake on my 97 heads.
You are stating you put it together without noticing/checking port alignment?
The diff is pretty obvious. My guess is that you'd have noticed it, if it were diff from the head ports.
Old Jun 13, 2003 | 10:11 PM
  #22
PoorMan's Avatar
Well, I know that the 93z's were not sequential injection. That started in 94. So their is a difference.
Jeff D
Old Jun 13, 2003 | 10:19 PM
  #23
DiabloZ's Avatar
Jeff D
That just has to do with how the computer is programed to fire the injectors, Not the physical part of the manifold.
oldschool
Feb 9, 2016 09:21 PM
onefastgta
Mar 19, 2015 10:10 AM
formula218
Dec 2, 2014 04:27 PM
thenewkid
Nov 27, 2014 09:41 AM
Jul 4, 2005 05:00 PM
