Air valve broke any suggestions?
Old May 1, 2006 | 12:45 AM
dubbsix's Avatar
I just put on headers and on the way home my old air valve broke off from the connector going into the header. Any suggestion on how to patch that up? I tried removing the buttom half, but it seems to be stuck inside the header.
Would using a torch to heat it up and make it expand.. help if its been stripped inside the header?
Old May 1, 2006 | 02:25 PM
dubbsix's Avatar
Re: Air valve broke any suggestions?
In case anyone else runs against this issue here is what i did:
Soaked the fitting with PB Blaster
Tapped the fitting a couple of times
Sprayed PB inside of the fitting
Tapped..
Then used a 1/2" breaker bar to break it loose.
Old May 1, 2006 | 02:46 PM
Zeueses 97 RamAir's Avatar
I have the whole thing I will ship it to you
Old May 1, 2006 | 05:39 PM
dubbsix's Avatar
thanks for the reply!
Found one locally.
HectorM52
Jul 30, 2017 11:46 AM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
oldschool
Feb 9, 2016 09:21 PM
95chwagon
Jan 13, 2015 09:19 PM
