Air tube only on one side?
Old Feb 6, 2007 | 08:38 PM
Imo000's Avatar
I have to hook up my air pump for emissions but the headers I have were used and the EGR port was welded shut. So I ran the EGR tube to the passanger side air port. However the CO reading is too high so I have to hook up the air pump too. I still have the driver side port avaialbe but the passanger is taken up by the EGR. If I hook up the air pump to only the driver side, will that be effective or does it have to run to both manifods? My concern is that the O2 will see a lot more oxygen on the dirver side and I don't know if this will make the emission readings worst. As soon as it passes the emissions I'm disconnecting the air pump.
Old Feb 6, 2007 | 08:44 PM
OBE1 95Z28's Avatar
The air pump is only active for the first 2 minutes after start-up, used to help heat-up the cats quicker by providing air (with O2). The air pump is not going to solve your CO readings.
HectorM52
Jul 30, 2017 11:46 AM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
95chwagon
Jan 13, 2015 09:19 PM
Jul 4, 2005 05:00 PM
