air pump resistor
Old Aug 2, 2004 | 12:30 PM
LT1 Bunny's Avatar
air pump resistor
Had a few fast questions, I did a search and I cant seem to understand what everyone is talking about with this bypassin the air pump with a resistor trick. I'm not spending 250 bucks for programming right now so I just want a quick fix.
Air pump is out, tubes, everything but the relay for the air pump and fuse. I'm going to use a 100 ohm 10 watt resistor. I know I have to use the brown wire thats under the relay box which is connector to the plugs for the air pump relay.
Here's the question, do I just cut that brown wire anywhere I want to and solder in the resistor??? Can I just use butt connectors instead of soldering??
Thanks for the help!
Old Aug 2, 2004 | 12:51 PM
944v8inDFW's Avatar
Re: air pump resistor
for the cost of a programming cable and 1 click you can program it out with Tuner just my 2 pennies.. Or with just the flash programmer from Tuner and a cable you could download the BIN from your PCM e-mail it to me and i will delete the air pump and email it back. Free of charge.
Old Aug 2, 2004 | 02:18 PM
LT1 Bunny's Avatar
Sounds like a great plan but I don't have an OBD1 PCM. I have to get it insected by the next cople of days (I like to wait till the last minute).
Anyone else can chime in whenever they want to!
944v8inDFW: Thank you for the offer too, I'll keep in touch with you. I have a 306 I need to put in and I'll have a lot of question for ya.
Old Aug 2, 2004 | 04:46 PM
LT1 Bunny's Avatar
TTT please, really need some help. Hate to cut the brown wire and it not work.
Old Aug 2, 2004 | 04:57 PM
Don't cut anything. Put your resistor in the harness plug for the AIR pump was. That will tell you if it is going to work without hacking up your wiring.
Old Aug 2, 2004 | 10:09 PM
LT1 Bunny's Avatar
Thanks Shoebox, i will give it a try and post my results.
Old Aug 3, 2004 | 05:07 PM
LT1 Bunny's Avatar
stupid question but how do you know which connector to plug it into. theres three holes for the one plug that goes directly to the air pump. so far i put the resistor into the outer to holes. cant really tell the color of the wires but theres a black, and two other red looking colors. might be brown and red.
help me out here guys, i need it! thank you so much for the help too be the way!
Old Aug 8, 2004 | 08:17 PM
LT1 Bunny's Avatar
k, supposed to be brown wire..............................................
100 ohm 10 watt resistor doesnt work............
nobody knows????????????????????????????????????????????? ????
HectorM52
Jul 30, 2017 11:46 AM
Magenta_Hearts
Mar 22, 2015 03:36 PM
Magenta_Hearts
Mar 5, 2015 07:01 AM
cmdeshon
Dec 27, 2014 10:06 AM
