AIR pump removel?
Old Aug 28, 2004 | 03:26 PM
Evilfrog's Avatar
AIR pump removel?
Im getting a set of BBK ceramic street legals for my car. My cat is going to be hollow but still there. Should I get another AIR hose and re-install it, or should I take it off? I do plan on keeping the stock manifolds/y-pipe if a Cat, to change in incase I have problems with emissions.(me? Never?) So if i remove the system, i want to know how to plug up the hole in the back of my manifold so It can easy be replace.
Summary
Remove AIR?
How to plug up hole in back of intake?
Removel of AIR pump without throwing codes?
_________________
Old Aug 28, 2004 | 03:41 PM
LOW TRAC's Avatar
Re: AIR pump removel?
I was having trouble with mine recently and it was setting codes and the SES light all the time, constant open loop. Anyway, if the option is there to hook it back up do it. It dosen't rob any horse power and will keep the O2s happy, unless you have sims the O2 sensors will go nutty. Also if your ever thinking about putting a cat back on there you'll need it for sure, a cat won't last long with out the AIR pump.
Old Aug 28, 2004 | 03:56 PM
jdizzell's Avatar
Shouldn't be getting any codes if the air pump is uninstalled. The air pump is only used durning cold start up to dilute the rich exhuast fumes for the cat. Your O2 sensors are not in use during open loop.
I think the size plug you need is a 22mm which is hard to find. Alot of people will say go to NAPA, but I have not found one yet to carry that size. I just put 5 pennies inside the hole sealed it with rvt cooper and keep the AIR tube on untill I can a hardware store that carries this size plug.
HectorM52
Jul 30, 2017 11:46 AM
linz
3rd Gen / L98 Engine Tech
Oct 22, 2015 07:59 AM
Magenta_Hearts
Mar 22, 2015 03:36 PM
Magenta_Hearts
Mar 5, 2015 07:01 AM
