Air Pump Problem
Old Nov 4, 2006 | 01:55 PM
LT1_King's Avatar
Air Pump Problem
My car cuts off at 4000 rpm under hard acceleration and smokes black at tips and has a rough idle. It blows out fuses to the air pump. When I put a new fuse on and run it for a little bit, it seems to run fine til after a while it starts sputtering. When I park it blows the fuse out. WHat could cause this?
Old Nov 4, 2006 | 05:02 PM
2000GTP's Avatar
This should help:
http://web.camaross.com/forums/showt...ir+pump+recall
Old Nov 4, 2006 | 06:08 PM
The AIR pump only runs for a few minutes on a cold engine, then shuts off. Not sure why/how it would be affecting your drivability problems.
Old Nov 4, 2006 | 08:55 PM
LT1_King's Avatar
so why would it be blowing out the fuses?
Old Nov 4, 2006 | 11:56 PM
Did you look at the explanation in the link posted in the first reply?
HectorM52
Jul 30, 2017 11:46 AM
linz
3rd Gen / L98 Engine Tech
Oct 22, 2015 07:59 AM
cmdeshon
Dec 27, 2014 10:06 AM
CamaroZBoy
Sep 9, 2002 10:33 AM
CamaroZBoy
Sep 1, 2002 09:48 AM
