Air Pump Problem
Air Pump Problem
My car cuts off at 4000 rpm under hard acceleration and smokes black at tips and has a rough idle. It blows out fuses to the air pump. When I put a new fuse on and run it for a little bit, it seems to run fine til after a while it starts sputtering. When I park it blows the fuse out. WHat could cause this?
This should help:
http://web.camaross.com/forums/showt...ir+pump+recall
CamaroZBoy
Sep 9, 2002 10:33 AM
CamaroZBoy
Sep 1, 2002 09:48 AM
