Air Pump : PCM or Fuse??
Old May 18, 2004 | 01:22 AM
MikeyNutt's Avatar
My Z had the SES light going on and off so I replaced the AIR Pump but I still have the same problem.
My mechanic checked it via a Snap On Diagnostic Computer and it he said it's either the PCM or the relay.
I don't think it's the relay.
If it's the PCM, what do I need to do??
By the way, I have the HPP installed, do I have to reset to original settings??
Thanks~~
Old May 18, 2004 | 07:57 AM
Impossible to know what kind of problem you are having unless you post the code you are getting.
Old May 18, 2004 | 08:48 AM
Releacez28's Avatar
reset programmer
I would program back to stock and check it again. I had similiar problem where Mr. Goodwrench could not find problem either, he went from PCM, to MAF, and everywhere between. Anyway after he unhooked tuning he found it. I don't know but i would try it! Yah shoebox is right find out what code it is first. good luck1
Old May 19, 2004 | 10:58 AM
MikeyNutt's Avatar
Sorry guys, I didn't get the code.
If it's the PCM, do I reset the HPP to the original settings??
I'll try to get the code.
Thanks~~
HectorM52
Jul 30, 2017 11:46 AM
linz
3rd Gen / L98 Engine Tech
Oct 22, 2015 07:59 AM
97SSdude
Dec 31, 2014 07:43 PM
cmdeshon
Dec 27, 2014 10:06 AM
