AIR pump making loud hissing sound on startup
Old Feb 3, 2006 | 06:13 PM
KeVMaN's Avatar
Lately, when I start up the car when it's cold (like sitting over night) it starts fine, but then when i put it into reverse or drive, it bogs down to like 300rpm and there's a loud hissing sound that sounds like the A.I.R pump that lasts for a few seconds, and then the idle comes back up to normal. Is there a leak somewhere in the system? What else could cause this? I've also been getting terrible gas mileage (like 10-14 mpg on the freeway) and i'm not sure if this is related. Any suggestions?
Old Feb 3, 2006 | 09:55 PM
96camaroSS's Avatar
Re: AIR pump making loud hissing sound on startup
Sounds more like a vacuum leak than anything else. I wonder if the torque of the engine when you put it in gear is moving something enough to create a leak. The only vacuum line I can think of that isn't attatched or affixed to the engine would be the line going to the power brake booster. You might want to check there. It would also account for the lousy mileage.
Old Feb 4, 2006 | 06:37 PM
KeVMaN's Avatar
where is this line at? i'd imagine it goes to the brake booster but what does the other end connect to?
Old Feb 4, 2006 | 08:27 PM
96camaroSS's Avatar
It's a 1/2" rubber hose coming from the driver's side of the intake manifold. It should be clamped to the nipple that is threaded in to the manifold and clamped to the fitting on the booster. I'm sure the clamps are there. You might want to pull it off and check it over very closely for cracks. If you find even the smallest of cracks it would still be one hell of a vacuum leak since it comes directly off the intake.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
HectorM52
Jul 30, 2017 11:46 AM
95chwagon
Jan 13, 2015 09:19 PM
cmdeshon
Dec 27, 2014 10:06 AM
