Air pump delete pulley
Old Oct 24, 2006 | 05:27 PM
MysticTeal95Z28's Avatar
Is there such a thing as an air pump delete pulley? If so, where can I get one? Thanks.
Old Oct 24, 2006 | 05:36 PM
2000GTP's Avatar
No such thing because it isn't belt driven like the old third gens. Its electric.
Old Oct 24, 2006 | 05:44 PM
OK, so is there a way to route the belt without hooking it back up or what?
Old Oct 24, 2006 | 05:47 PM
seawolf06's Avatar
The belt doesn't go around it or anything, so you don't have to reroute it. You just unplug the pump. Are you sure you deleted the AIR pump?
Old Oct 24, 2006 | 05:50 PM
2000GTP's Avatar
I'm getting confused here, its electric so it's not belt driven at all. Are you mistaking it for the A/C delete pulley by chance?
Old Oct 24, 2006 | 05:57 PM
seawolf06's Avatar
Sounds about right.
Old Oct 24, 2006 | 07:06 PM
...there is a point being missed somewhere...
Old Oct 24, 2006 | 07:54 PM
Haha yeah I was being dumb, I think what we were looking at was the power steering pump, (it is under the alternator, right?) Nothing has been delteted yet, I'm just working on getting Hooker L.T.s in my car and we just got the driver-side manifold off tonight and we quit for the night. We're taking it little by little. The passenger side is going to be a P.I.A.
Old Oct 24, 2006 | 07:57 PM
2000GTP's Avatar
Yeah, you were looking at the P/S pump. The passenger side is a pain, what way are you going to put them in, top or bottom? I put mine in through the top, but I had to remove the valve cover and alternator. Not a big deal though.
The alternator has already been moved, no biggie there. However the valve cover is still on.
Do you have emissions legal Pacesetters, 2000GTP?
Old Oct 24, 2006 | 07:59 PM
2000GTP's Avatar
Only reason I had to remove mine was to provide just a hair bit more clearance for the EGR fitting on the header to clear.
Old Oct 24, 2006 | 08:03 PM
The A.I.R. system fits on the manifolds, right? Not the EGR?
Old Oct 24, 2006 | 08:05 PM
2000GTP's Avatar
The AIR system connects to the top fittings on each manifold. The EGR connects to a single fitting on just the passenger side manifold.
HectorM52
Jul 30, 2017 11:46 AM
armedtrigger
Feb 24, 2015 08:30 PM
Jason Short
Jan 19, 2015 06:34 PM
cmdeshon
Dec 27, 2014 10:06 AM
