air pump bleeder
Old Mar 9, 2010 | 12:45 AM
camarorz28's Avatar
air pump bleeder
i broke a part while trying to put the distributor back together. From the Air pump on the outlet hose going to the manifold there is bleeder valve that has nipple and a hose coming off from the main outlet hose from the pump. Does anyone know of major importants??? i got a picture from shbox.com
http://www.shbox.com/1/air_pump_recall.jpg
the first picture on the left where it says bleeder valve harness(96-97)
if your follow the hose it connects in between the output hose from the air pump.Does it really need it????
Old Mar 11, 2010 | 11:51 AM
camarorz28's Avatar
anyone???
Old Mar 11, 2010 | 12:21 PM
camarorz28's Avatar
after doing some research, that bleeder valve is not so necessary??
https://www.camaroz28.com/forums/sho...d.php?t=691883
someone had a question about it, well on my car the nipple just broke. If i seal the hole it should be fine?
HectorM52
Jul 30, 2017 11:46 AM
linz
3rd Gen / L98 Engine Tech
Oct 22, 2015 07:59 AM
Magenta_Hearts
Mar 22, 2015 03:36 PM
Magenta_Hearts
Mar 5, 2015 07:01 AM
