Air pump
Air pump
Hello all, I have a 95z and took the fuse out for the air pump. The down fall for this is the check engine light comes on. The question is, does the PCM go into closed-loop or open-loop when the check engine light comes on?
Thanks Z95M6, The air pump is good, The reason for taking the fuse out was so the fans would come on and stay on. Havent had time to do the fan mod yet. With the 160 t stat my temp never exceeds 190 with the fans on.
If you pull the fuse, the computer detects that the smog pump is not working, turns on the SES light, and goes into "limp home" mode. The fans are on full time, and the computer defaults to conservative settings for timing, fuel, etc., so you will likely be down on power.
stockssn2o
May 25, 2015 08:54 AM
Magenta_Hearts
Mar 22, 2015 03:36 PM
Magenta_Hearts
Mar 5, 2015 07:01 AM
