air pump
Old Sep 21, 2003 | 10:31 AM
camaroguy94's Avatar
air pump
ok i don't know if this is a problem but i was checking the fuses today and my air pump fuse says it is suppose to be 20 amps but it has a 25 amp fuse in it. should i replace the fuse?
Old Sep 21, 2003 | 01:59 PM
NVetro's Avatar
Time for EGR and AIR deletion But for your issue, i dont see why i a higher amperage fuse will hurt anything, i can understand it being lower and causing a problem, but higher shouldn't do anything. Guys, am i right on this one?
Old Sep 21, 2003 | 02:08 PM
killerkelly95's Avatar
Ok Dude, how you a woman know right? Well I know and there is nothing wrong with having your amps to high i think it is better being higher than lower cuz lower will only cause problems so hope goes well
Old Sep 21, 2003 | 02:13 PM
NOMAD's Avatar
Cool
You = Teh Gramar
A lower amp fuse will not handle the proper current needed for the application, therefore blowing the fuse.
Be careful of higher amp fuses though as they could be pointing to another problem, such as something wrong with the air pump, blowing the correct fuse. Then someone installs a higher amp fuse to cover up the actual problem, which could lead to AIR pump failure, or even over loaded and burnt wires.
My opinion, don't worry about it since it's only 25 amp
-Shannon
Old Sep 21, 2003 | 08:48 PM
curly's Avatar
If the car had the factory TSB for the wiring harness for the air pump, then the fuse was replaced with a 25 amp. You could look to see if a new heavier guage wire was run to the airpump (it should have been). I had the TSB done after blowing fuses and replacing the airpump on my 1995. I don't know if this TSB covered 1994 cars also. I have a copy of the TSB if anyone would like a copy (which I scanned into a Word document). I will be removing all of this (Air pump and EGR) during my upcoming longtube install .
HectorM52
Jul 30, 2017 11:46 AM
linz
3rd Gen / L98 Engine Tech
Oct 22, 2015 07:59 AM
Magenta_Hearts
Mar 22, 2015 03:36 PM
Magenta_Hearts
Mar 5, 2015 07:01 AM
