AIR for header installation. HELP!!!!!!!!!!
Old Jul 14, 2004 | 07:56 AM
95camaro z28LT1's Avatar
i just installed my pacesetter headers. the air didn't even line up in the first place. when i took it of the tube and tried threading it, it wouldn't
i called pacesetter and didn't help me out at all.
i am thinking of getting 22m drain plugs to plug the fittings on the headers and then getting a rubber plug to plug the air tubes and finding a way to connect the valves and tubes later.
question is, will this throw a SES light if i do this.
any help will be appreciated.
Old Jul 14, 2004 | 09:42 AM
cmking26's Avatar
Should'nt throw any codes for an OBD1. Mine didnt, I just tied electrical connector up out of the way. Make sure you plug all hoses so you dont have a vaccuum leak and you'll be fine.
Old Jul 14, 2004 | 02:52 PM
grygst76's Avatar
Also keep the fuse in, if removed it will set the service engine light
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
k1996z28
Jan 21, 2015 07:22 AM
95chwagon
Jan 13, 2015 09:19 PM
Collector Car
Jan 5, 2015 10:58 AM
