AIR crossunder pipe
Old Aug 25, 2003 | 09:35 PM
ibanez6rg's Avatar
AIR crossunder pipe
How did you guys end up removing this pipe for the AIR system? (metal pipe)
Old Aug 25, 2003 | 09:42 PM
94formulabz's Avatar
sawzall at the bottom
Old Aug 28, 2003 | 04:41 AM
revtime's Avatar
How the hell did you get a sawzall in there?
I used a dremel with a cut off wheel.
Went like butter.
Old Aug 28, 2003 | 05:36 AM
texasTA's Avatar
Same here, a dremel with a cut-off wheel. Just make a single cut in the middle, then take out each side. Just wiggle up and down and the sides will come out. If you can fit a sawzall in there, I would give you 100.00 bucks.
Old Aug 28, 2003 | 05:49 AM
ishz28's Avatar
Dremel with a cutting wheel.
Old Aug 28, 2003 | 07:53 AM
Hmm, maybe i made two cuts, from 4:30, 7:30? Don't remember though, definitly used a sawzall though.
Ya think thats where that giant oil leak came from ya think??? jk
Old Aug 28, 2003 | 10:23 AM
PatriotTA's Avatar
Man, I'd like to see someone get a sawzall under there. I used an air die grinder with a cutoff wheel and made two cuts.
Old Aug 28, 2003 | 11:10 AM
CamaroBoy96Z28's Avatar
Mine's still there.
Old Aug 28, 2003 | 11:15 AM
ksmyss's Avatar
Originally posted by CamaroBoy96Z28
Mine's still there.
LMAO i still half half of mine wedged in there too
Old Aug 28, 2003 | 11:18 AM
ibanez6rg's Avatar
I've tried tree trimmers And it just tore up my Dremel blade
Old Aug 28, 2003 | 11:22 AM
PatriotTA's Avatar
Mine's still there.
Getting mine out wasn't hard. I made one cut in the front, before it bends around the oil pan, and one in the rear, i think it was kind of in the center of the oil pan. It was awhile ago. I used pliers to grab the pipe and twist it and finnesse it out of there.
Old Aug 28, 2003 | 11:53 AM
bradpreece95z28's Avatar
where's my 100 dollars?
I used a sawzall last night as a matter of a fact on the crossunder pipe!
It wasnt that hard, just have to MIND THE OILPAN!!
HectorM52
Jul 30, 2017 11:46 AM
Noct
May 26, 2016 10:26 AM
95chwagon
Jan 13, 2015 09:19 PM
