AIR block off
Old Jun 12, 2005 | 07:43 PM
heitz's Avatar
AIR block off
Anyone know where to find a scale diagram of the block off plate for the air pump.thanks
Old Jun 12, 2005 | 11:01 PM
Re: AIR block off
What blockoff plate? The AIR pump pulls air out of the plastic air inlet duct (5/8" vacuum cap required to block the connection), and blows the air through the tubes, hoses and check valves into a single connection on the header (or exhaust manifold) on each side of the engine. Those connections require a threaded plug to close off.
Is it possible you are looking for a blockoff plate for the EGR valve and/or the EGR riser pipe that runs from the #8 primary to the back of the intake manifold?
F'n1996Z28SS
Aug 23, 2023 11:19 PM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
95chwagon
Jan 13, 2015 09:19 PM
