AI heads+JoeO cam+LT's+Loudmouth=Idle
Old Apr 24, 2004 | 09:38 PM
simple's Avatar
http://www.unrealhp.com/stevez/simple.wmv
thanks to all the people that helped me figure out the lil things with the install!! thanks to Joe for the cam and Phil for the heads
Old Apr 24, 2004 | 09:43 PM
jsz28's Avatar
very nice
Old Apr 24, 2004 | 10:43 PM
Fastbird93's Avatar
That sounds awesome!!!! I'm in the process of a very similar thing and can't wait for it to be done!
Old Apr 25, 2004 | 01:12 AM
simple's Avatar
its got some part throttle issues that need to be worked out
i've only put ~16 miles on it so far (all below 3000rpm)
and i need to get my damn fuel pump in there as well
Old Apr 25, 2004 | 01:21 AM
StrokerWannaB's Avatar
what kinda #'s are you expecting to put down? and what did your build consist of? I plan on a 355 stroker (hopefully this summer) and i would KILL for that kinda sound. When you get everything figured out, vids of WOT would own man. Nick
Old Apr 25, 2004 | 01:22 AM
97WS6SCharged's Avatar
Aren't cams fun? I've been driving around with my new 224/236 with my supercharger unhooked and everyone in town is looking for a piece of me. Poor slow bastages, they just can't keep up. Now to fix my tensioner.
Old Apr 25, 2004 | 01:23 AM
simple's Avatar
bone stock bottom end (82,000miles)
i dont want to guess any numbers but i think what others have been doing with similar setups is a good way to compare
p.s. a 355 isnt a stroker its just an overbore, well with a 350 anyway
Old Apr 25, 2004 | 01:25 AM
stokc bottom end, why not build while you had her out of the engine bay? So you did CAM, Heads, and headers? Not bad at all man. I would love to do that, but i have 163k on my 96 Z28 man so not touching the bottom end is outta the ? for me. Sounds AWESOME!
Old Apr 25, 2004 | 01:28 AM
simple's Avatar
the cylinder walls were flawless, you could still feel the cross hatching plus money isnt there right now for a bottom end, once it is tho it'll just be a budget 355 (forged pistons, eagle rods, stock worked over crank)
then accel DFI and rev it as high as i can
and all the work was done with it in the car, you'd be surprised how much room there is with everything removed.....enuf for 2 people to stand in there
Old Apr 25, 2004 | 01:31 AM
You can do heads and cam with the motor in the car. I just did.
If you're not doing some serious nitrous or a turbo, a DFI unit is a bit of a waste, unless you intend to still be making power at 7000+ RPM.
Old Apr 25, 2004 | 01:32 AM
NO ****! i thought you had to pull it out for a cam and head job. That is GOOD NEWS! how many hours did you have into the job? Thanks, Nick
Old Apr 25, 2004 | 01:36 AM
can i ask how much you have into the heads and cam setup alone?
Old Apr 25, 2004 | 01:38 AM
simple's Avatar
well when the bottom end comes around i plan on turning it into a solid roller....so the DFI would come in handy
about $2k in the cam and heads, cam is billet
Old Apr 25, 2004 | 01:41 AM
that is not too bad i am planning on about 3200 after machine work and everything for my 355...think that is reasonable? Nick
Old Apr 25, 2004 | 01:51 AM
Yeah, as long as you don't want a billet cam.
