Aftermarket LT1 heads
Old Apr 22, 2012 | 07:51 AM
rsjay's Avatar
I am rebuilding my 1994 LT1 Camaro. I already have LT4 hotcam, 52mm TB, 1.6 rockers, stock heads, catback, headers, 3.42 gears, PCM tune, and ram air. I was looking at Trick Flow heads for my setup. Would this be a good combination for what I am currently running and are there any other reasonable priced heads that I can use?
Trick Flow® GenX® 185 Cylinder Heads for GM LT1
TFS-30400008-M54
Old Apr 22, 2012 | 10:20 AM
RamAir95TA's Avatar
Re: Aftermarket LT1 heads
TFS-30400008-M54
I would say no.
If you're planning on doing the heads you might as well change that dinosaur cam to something that will put a huge smile on your face. Adding the heads with that cam will give you some extra oomph, but not nearly as much as ported stock castings and a custom grind cam. Just adding those heads and that cam might get you 35-360whp, but something like AI 200cc heads and a custom grind will easily get you over 400whp - for only marginally more $ than those Trick Flow heads.
Old Apr 22, 2012 | 09:49 PM
CamDriver's Avatar
not a fan of the lt4 cam at all!!! its a waste of time..
Old Apr 23, 2012 | 01:05 PM
Orr89rocz's Avatar
Depends on what you are looking for. how high you want to spin it? Any particular purpose to this car? drag? road race? weekend cruiser? ET goals? HP goals? On a budget? Alot to think about before picking heads/cam combo.
Old Apr 26, 2012 | 05:46 PM
my94blackz's Avatar
Junk the cam and port the stock heads. Hot cam=junk.
Old Apr 26, 2012 | 06:59 PM
96capricemgr's Avatar
I wouldn't call the HOT cam junk but it is rather old and if looking for more power and looking to swap heads I would be replacing it.
I would second Joe's recommendation of AI 200cc ported stock heads
Rod Bender
Jan 1, 2015 03:18 PM
TireSmoke
Aug 6, 2002 10:25 PM
Snake Slayer
Jul 29, 2002 12:39 PM
95 Mystic TA
Jul 29, 2002 08:50 AM
