after replacing oil pressure sending unit?
Old Apr 2, 2006 | 09:57 PM
crAzy95z28's Avatar
the oil pressure now reads even lower.
Is there a possibility the unit is too tight?
caus now my car read at 15psi at idle and sometimes lower and at cruising it read like 35-38 psi.
Old Apr 2, 2006 | 10:38 PM
Re: after replacing oil pressure sending unit?
Could just be the difference in that unit or maybe it is really correct. Is it an AC-Delco unit or another brand? Verify pressure with a mechanical gauge.
Old Apr 2, 2006 | 10:41 PM
crAzy95z28's Avatar
its a duralast from autozone.
havent checked it with a mechanicle guage. Not that hard with one is it?
just hook it up where the unit us?
Old Apr 2, 2006 | 11:00 PM
You can use the auxiliary port by the oil filter for a gauge.
Old Apr 2, 2006 | 11:14 PM
crAzy95z28's Avatar
cant i just take out the unit and put it there? cause i really dont feel like getting under the car and doing all that.
Old Apr 3, 2006 | 12:08 AM
crAzy95z28's Avatar
little off topic but when putting the pickup on the oil pump. The screen is suppose to face up towards the car, instead of facing down towards the ground correct?
Old Apr 3, 2006 | 07:09 AM
Sure, but it's probably easier to do on the side, plus you can keep the original gauge. Whatever you want to do.
Old Apr 3, 2006 | 07:11 AM
How can you put the pickup on the pump with the screen facing up? It faces down. Maybe you should post a pic of what you mean.
Old Apr 3, 2006 | 07:31 AM
1racerdude's Avatar
Don't think that will work.
Old Apr 3, 2006 | 10:18 AM
crAzy95z28's Avatar
just a thought in my head. Since the pickup faces the front of the car, turning it around to face the back of the car makes the screen face up.
But besides that. Why would this new part make the pressure even worse?
BADAZZ_Z
Parts Wanted
Mar 5, 2019 12:55 AM
HectorM52
Jul 30, 2017 11:46 AM
transam_388
Mar 15, 2015 11:53 AM
phoenix95
Jan 8, 2015 02:44 PM
phoenix95
Jan 8, 2015 09:14 AM
