after header install..rubbing? help
Old Jul 29, 2004 | 01:34 PM
customlt1's Avatar
Installed hooker long tubes and right when i start my car you can hear one of my headers rubbing..the guy that installed them said its from the engine idoling when it starts..you can only hear the noise when im letting off the clutch or when i first start my car..he said he tryed making a bracket but i guess that didn't help? anyone else have this problem and/or resoultions?
Old Jul 29, 2004 | 08:47 PM
CoUnTryMuZiCZ28's Avatar
Re: after header install..rubbing? help
I had this problem with jet hot long tubes.. it was hitting the K member. I grinded it down alot compared to how it was, now that my motor is out, I really cut it down to size. The other place it can be hitting if they are long tubes is by the tranni mount.. They run right near it, if your running a y pipe.. Take the y pipe down and get a 4 angle grinder, a dremel youll be there all day for this, then just grind it down till you think it wont hit.. http://www.theheadfl.com/jethotlt.htm.. Thats a good install page, at the end of the install page he will show you where he grinded.. or just click here... http://www.theheadfl.com/pics/headers49.jpg... If its rattling in the back of the car its probably your cat back where it goes over the axle hitting the side of the car, youll see when you get under there.. for that just take a crow bar and pry it away, try not to dent the pipes, use a flat pry bar if u can..
sherwinZ28
11
Aug 15, 2015 05:38 PM
colts0455
Jul 28, 2015 11:28 PM
jbc3
Jul 28, 2015 12:24 PM
Strick
Jul 14, 2015 07:28 AM
