AFR's customers here..
Old May 11, 2005 | 12:53 PM
  #16
CANTONRACER's Avatar
Re: AFR's customers here..
Well, the valves are not a culprit in my soon to be issues...the constant checking of my 250 lbs closed, 700 lbs open springs are a whole other story
Cam plays a massive role in the driveability factor...my custom small base circle billet grind solid roller with 257/261, 106 CL, .648/.648 might be another story though
But seriously...tuning is the key. I have good resources and unlimited use of a dyno to help me out.
Old May 11, 2005 | 03:51 PM
  #17
mongse_1's Avatar
Originally Posted by RealQuick
So, when you flow tested them did you use the same bore size and a pipe on the exhaust? If so, thats fine, but people need to understand that the high exh. numbers AFR sees will be much lower if flowed without a pipe like most head porters test.
From what I remember, 350 plate, no pipe. I never thought AFRs numbers were that high on the exhaust side. Now TEA, that's a different story.
Mine were nothing fancy. Just the average 2.08/1.60 valve arrangement. I did make some changes on the exhaust side since they are on a turbo car.
Old May 12, 2005 | 07:13 AM
  #18
RealQuick's Avatar
What changes? More porting? Mine are going on a turbo setup as well.
Old May 12, 2005 | 09:31 AM
  #19
mongse_1's Avatar
I opened up the exhaust side as much as possible. I tried to recreate a D-port, then enlarge the sides, but I cut through a wall. Simple fix w/ a TIG though.
I thought about trying some tricks w/ the intake runners, but figured I'd see how the exhaust work did before I push more air into the chamber. If I need more power, I can just turn the dial.
95chwagon
Oct 16, 2015 12:24 PM
kandied91z
Sep 30, 2015 11:43 PM
CARiD
Sep 30, 2015 05:44 AM
sleeperZ96BT
Sep 10, 2015 08:01 AM
