AFR190 54cc Heads Intake angle not right, what to do?
Re: AFR190 54cc Heads Intake angle not right, what to do?
That makes no sense. THey list the 190 (Not made anymore) and the 180 (New version of the 190) as LT1 heads and the 195's and up as LT4. I would think since they list a dif between the two that one would use LT1 and one LT4, they also state in the discription for the 195+ heads that a LT4 intake must be used.
Originally Posted by RobBeck
Update:
Spoke with Tony Mamo yesterday (really cool guy BTW), about this whole situation. He instructed me to measure the distance from the dowel pin alignment hole to the intake flange surface corner and to report my findings, ultimately this will truly tell how much material had been removed vs. a stock casting. My measurement came up to 6.060", whereas he says the stock UN-milled casting is 6.120" (he also calculated 6.070" for a new 54cc casting)... which seems to be correct by judging by some measurements of the block. Anyway, he said the problem is with the fact that I have 54cc chambers... which require 1* angle mill from the stock 76cc castings. That 1* apparently has caused the ~.060" material loss during the Intake correction procedure. I advised him my biggest problem is the port alignment with the stock LT1 Intake.... the ports are REALLY low and dont line up with the heads well (severe port matching required and even yet the Intake Manifold roof would be left paper thin/wouldnt seal). He said that I need to use the LT4 intake, that it has raised runners and will line up with my head runners unlike my stock LT1 Intake. So now I have to source an LT4 Intake, to try to confirm these new thoughts. Tony said that they recommend using the LT4 Intake with ALL of their heads (LT1 and LT4) because of such runner alignment issues. He also indicated that the bolts will ALWAYS be affected when doing an angle mill, requiring spot facing of the Intake manifold (or just ignore it)... I was under the impression that kind of stuff was all taken into consideration when I bought the heads. Anyway, the story as of now is the fact that I went 54cc and pretty much maxed out the castings is why I am having troubles with Intake Port alignment, etc. If the LT4 Intake Ports dont line up any better (the .100" raised runners I have read about will help ALOT), then its back to the drawing boards with AFR.
Rob
Rob
I have AFR 190 LT1 heads with 54cc chambers and 30K miles and never noticed a problem.
Tom Piper
Ok. Scratch the LT4 Intake deal... apparently the roof is raised but the floor is dropped too=too big of a port for my LT1 heads. AFR just called to confirm that and said that it wouldnt work to my expectations (nor theirs).
I do have some good news though, I just dug out some OEM GM Intake gaskets I had bought along time ago and they Mic out out .075"... mocked em up and things are Looking ALOT better. If I can gasket match some material off of the floor of the HEADS, and some more from the roof of the INTAKE AND GASKET (about .040" in each case)... I think I will be in business. What do you guys think?
Rob
Rob
That is what I thought, but he said it was even in their new literature about the LT4 Intake recommendation... I have never seen it though. Regardless they did call and correct that insenuation thank god cause I was about ready to buy one.
Rob
Rob
Tom Piper,
Out of curiosity what is your combo and do you have any performance data? Now that this thing is finally going back together would be nice to hear what I may/could be in for.
Rob
Rob
Update:Spoke with Tony Mamo yesterday.....Anyway, he said the problem is with the fact that I have 54cc chambers... which require 1* angle mill from the stock 76cc castings. That 1* apparently has caused the ~.060" material loss during the Intake correction procedure... I was under the impression that kind of stuff was all taken into consideration when I bought the heads.
I advised him my biggest problem is the port alignment with the stock LT1 Intake.... the ports are REALLY low and don't line up with the heads well...He said that I need to use the LT4 intake, that it has raised runners and will line up with my head runners unlike my stock LT1 Intake.
If the LT4 Intake Ports don't line up any better (the .100" raised runners I have read about will help ALOT), then its back to the drawing boards with AFR.
NOTE: (also in archives btw) Intake ports of LT4 heads are raised, the ports of matching intake are NOT. The casting does ALLOW the raising of the port roof, by porting procedure, however.
Tom Piper,
Rob
Rob
I've been running it that way for at least 30000 miles. No leaks or any other problems.
Tom Piper
As stated about 20x in this thread already no one touched the heads aside from AFR, when they were purchased new from them... then more recently when I sent them back to repair the Intake angle.
Tony did make the statement, I was searching info and pricing and was considering ordered the LT4 Intake but I got a call back earlier saying that it WOULDNT correct my problems... so I dunno maybe it was just a brain fart or something. Thanks for all your additional info regaurding the LT4 intake, looks like the LT1 should be fine.
Originally Posted by arnie
So, whom did the machining to get chambers down to 54 ccs in the first place?
WHAT? IF INDEED, TONY MADE THAT STATEMENT....That statement is NOT accurate. Tony may be a 'cool' guy, but doesn't know too much regarding the LT4 intake manifold, AGAIN, if he did indeed make that statement. Ports are NOT raised on the LT4 intake. If he claims to be familiar with the LT4 intake, I question his integrity. If his integrity is not at issue here, I find it sad the guy would know so little about a component he recommends, if indeed he recommended that manifold. (see below)
Port height of the two (LT1 and LT4) intakes, is identical. Doing a search will net you several posts/threads explaining the differences (rather lack thereof) of the two intakes.
I was looking more for performance figures (dyno, 1/4 mile, etc) and mods on your car... just curious how it runs.
As for my situation now, the Intake lines up quite a bit better with the thicker OEM gaskets.. they are .075" so that is nice.
I just want to point out that since I got thru to AFRs sales and customer rep team (Rick and Tony), that they have been EXTREMELY helpful and understanding thru this. Like mentioned above, with the OEM Intake gaskets, it appears that the ports line up well enough that some ~mild~ port matching should make it all ok. Looks like I am going to have to take about .040" off of the floor of the Head inlets and about .040" off of the Intake Outlet ceiling... and spot face the intake to match the angle of the bolts. When I get a bit deeper into the process I will know for sure (freakin freezing here), but I am now thinking the castings are acceptably fine. AFR said that amount coming off the floor of the heads would be no big deal for blending purposes.
Rob
Rob
Originally Posted by Tom Piper
I bought my AFR 190 LT1 heads with 54cc chambers, the chambers were done by AFR, about 1998. I have a stock LT1 intake with OEM intake gaskets. I looked at the match between the intake and heads before I bolted the intake on. I didn't notice any gaps in the two.
Tom Piper
Tom Piper
As stated about 20x in this thread already....
Ya this all makes sense. But based on the measurements I made from the dowel pin to the intake interface corner the measurements are inline with what AFR CLAIMS will be what I would get if they did in fact send me new castings (my castings were 6.060"... they said new 54cc castings would be 6.070" per their calculations, and the OE dimension is 6.120"). This is based on them angle milling my heads 1* to change the casting from a 76cc to a 54cc head. Probably based on some of my issues, they dont even send 54cc heads anymore... lowest available is the 56cc head. You are still right, and the smoke isnt necessarily cleared. When it warms up abit I am going to get some gasket paper and see exactly where I stand in regaurds to port matching. I will want AFRs buy off on it before I begin matching. If problems do truly still persist, I am sure AFR will do well on whatever it takes...
Also, just as an FYI per AFR. The intake bolt holes are all drilled in ANY head manufacturers head at the stock deck height. When you start angle milling (you or the company), you are affecting the bolt angle... which most people just ignore (and probably have no problems) or get it corrected (to do it right). If you ordered a set of their 76cc castings today at their lowest 56cc available design, you would have bolts that are off abit just like mine.
Thanks again for your support.
Rob
Rob
The one problem I see, regarding your situation, is that the heads were bolted on and run the way they came form AFR. Otherwise, you could have sent back still new heads. AT THAT JUNCTURE, PERSONALLY, would NOT have accepted anything less than a correct replacement, or credit card payment would have been frozen. That is the way I am, like it or not. Don't know 'bout you, but I EXPECT, and WILL receive what I pay for. I will not be jerked around by 'questionable' dialogue. Again, like it or not, the way I am. I am a man of principle, and a man of integrity. If I am unable to receive a product backed by integrity, payment of funds is put in jeopardy. Credit card purchases have their advantages. If this was a rant, so be it. Again, wish you well.
oldschool
Feb 9, 2016 09:21 PM
95chwagon
Jan 13, 2015 09:19 PM
