AFR 195's(street port) vs fully ported stockers???
Old Apr 20, 2003 | 09:33 PM
RiceETR96's Avatar
OK,
So I am building a 383, mainly an NA setup. But I am sure that curiosity will force the bottle into the back of my car at some point. Here is a quick run down of the setup. SCAT 9000 series cast crank, SCAT forged H-beam rods, SRP forged flat-top pistons. Now, what I am trying to decide on is weather or not to go with the AFR LT4 195's. I saw the flow numbers that AFR puts out for these, and almost any well know place that ports LT1 heads(Nu-tek, ComboMotorsports) can do better than 262@.600/194@.600, and the fall back to buying them is then I not only have to spend an extra $300 for them(over stockers). I also have to buy a different intake. I can sell my stockers for $200 to make up for most of the intake. I see a plus to this though. If one day I want to make it a bit faster then I figure all I'll need is to get them hand ported to reach their full potential. So I am open to all opinions, thanks for your help.
Old Apr 20, 2003 | 09:59 PM
merim123's Avatar
You've got the same dilemma going I do. My shortblock is ready (i'm doing 355 w/ 222/230 cam) and I'm trying to decide on the direction for heads.
As far as what people have told me, AFR's are great heads and are better castings than GM's. I was told to consider them an investment for the future. As for bang for the buck, they probably lose to a well ported LT1 casting by some of the guys on the board (like Phil, combo, Lloyd). Everyone seems to be running 380-420rwhp with the setups these guys are creating so the power is there in a LT1 casting.
I'd start with bang for the buck vs. investment. Once you make that decision, than you can decide on direction. I still haven't made this decision.
Old Apr 20, 2003 | 10:00 PM
mr diabolical's Avatar
the AFRs have better runner and chamber design. and thats not the max potential out of them. look at the 200cc and up chambers too if your going with a healthy cam.
Old Apr 21, 2003 | 03:21 PM
RiceETR96's Avatar
Thanks for your help guys, Yeah I am thinking bang for the buck right now.
Anyone else?
Old Apr 21, 2003 | 03:31 PM
Perry93TransAm's Avatar
I went from a set of ported GM castings to a set of 190cc AFRs (blew a head gasket and ruined one of the GM heads) and was very pleased witht he improvement. I ran a best of 12.39 @ 111 with the ported stockers (with bigger valves and they flowed in the 255 to 260 range) . With no other cahnges but bolting on an out of the box set of 190cc AFRs I ran a 12.22 in warmer weather !!! I was impressed, when this motors bottom end goes and I build a stroker I plan on porting these heads .
Old Apr 21, 2003 | 10:25 PM
RiceETR96's Avatar
Nice. Anyone else got these heads?
Old Oct 25, 2003 | 03:05 PM
Dave88LX's Avatar
Not sure how far along you are...but you mentioned you had flat tops...did you bother to figure out what your compression ratio is going to be
If you're running flat tops you will probably need a larger head cc...
Old Oct 26, 2003 | 07:20 PM
BES-383's Avatar
Runing stock ported heads on my set up. Flowed 290 .. check out #s in my sig.
Old Oct 26, 2003 | 07:26 PM
FacelessZ's Avatar
yea ported stockers can run ~275/190 @ .600 lift if you port the hell out of em
~215/150 out of totally stock LT1 heads...
Old Oct 26, 2003 | 07:29 PM
94formulabz's Avatar
I think merim123 summed it up pretty well.
Old Oct 26, 2003 | 08:17 PM
got_hp?'s Avatar
on your page.........it says BES installed hardened valves.........did they do any porting, or was its strictly from lt1dave?
btw, your engine is badass..........how much did the engine itself cost?
why did you choose to run the DFI?
Old Nov 7, 2003 | 03:12 PM
Dave88LX's Avatar
ttt
Old Nov 7, 2003 | 03:26 PM
DamianLT1's Avatar
Just an FYI a car in not an investment. You will never make back nearly the $$$ that U put into it. So with that being said unless you are planning to run street races for $$$ your best bet is the Stock one's. There's enough power there and it won't cost you a arm and a leg.
LeftoverChinese
Jan 14, 2024 03:03 PM
mightymouse383
Jul 20, 2016 07:34 AM
95chwagon
May 27, 2015 09:53 AM
dfarr67
Apr 10, 2015 07:44 PM
super83Z
Jul 11, 2002 10:16 PM
