adjusting your idle speed
you can pull the PCM/BATT fuse, adjust the throttle blade screw maybe a full tuen at a time... wait a min or 2, reinstall the fuse and start it back up
just repeat the process until you get the idle where you want it, just pull the fuse each time tho
done it on mine quite a few times to adjust the idle and its fine
A stock TB on a 1997 should not need any adjustment to the stop screw. If you change it, the computer will just readjust the IAC steps to compensate and retain the idle speed that the computer has programmed into it. Unless you have special circumstances to need to change the minimum throttle opening, you should change the idle speed with programming.
jb4xx
Feb 2, 2015 10:00 PM
