Adjusting the timing gears...no chain
Old Jun 18, 2003 | 08:17 AM
BradZ28's Avatar
I'm replacing the timing gears and chain as well as the waterpump gear with the LT4 ED set. I need to turn the gears (cam and crank) so that the dots on the gears are next to each other. When I have the cam gear at 6 o'clock the crank gear won't move and when I have the crank gear at 12 o'clock then the cam gear won't move......anyone have any advice? I think it may have something to do with top dead center?
Oh...and I broke a bolt off in the cam
Old Jun 18, 2003 | 08:22 AM
joeSS97's Avatar
Remove the rockers,then you will be able to turn the cam.
Old Jun 18, 2003 | 08:29 AM
BradZ28's Avatar
If I take out one of the spark plugs would that release the pressure inside the cylinder that's at top dead center? When the timing mark on the crank gear isn't at 12 o'clock the cam gear spins very easily.......
Old Jun 18, 2003 | 08:38 AM
joeSS97's Avatar
Yes,you could do that too.Whatever is easier for you. You better fix the broken bolt too.
Old Jun 18, 2003 | 08:43 AM
BradZ28's Avatar
Yeah I suppose I better get that bolt out Do you or anyone else know which cylinder is up when the dot on the crank gear is at 12 o'clock?
Thanx Joe97SS
Old Jun 18, 2003 | 08:44 AM
The pressure bleeds off on the cylinder in a matter of seconds. You need to loosen the rockers like joeSS97 said. You are probably getting valve to piston interference because of the mis-timing of the cam and crank.
RUENUF
Mar 13, 2016 03:39 PM
grgguy
17
Feb 23, 2015 07:57 PM
Cam's maro
Jan 30, 2015 09:21 PM
Queens94z28
Dec 20, 2014 09:11 PM
ScottZ
Mar 3, 2004 01:34 PM
