Adjusting rockers while running
Hello, Did a search,didnt find specifics. I have the CC pro mags NSA. Seems like i have a tap on my driver side valve cover,different from the rest. What i need to know is,can you adjust the rockers while running and what should i expect when i start the engine with the valve cover off, oil squirting or what? Warm engine first? Seems like i read you loosen the rocker till oil squirts out then turn just till it stops-Any step by step ,saw Shoebox's site.-Any help please. Thanks Dwayne
ive adjusted that way and I don't think that adjusting till oil stops is the best way! I usually adjust till they stop ticking then add 1/4 turn. and as far as oil spraying I take and cut a piece of cardbard about 4-5" tall and adjust the width to set down into the bottom of the head while you have the valve cover off and it helps to keep oil from spitting out all over the headers.
Yeah Shoebox, went there, I went ahead and took valve cover off, there was no oil squirting anywhere so i quess i dont have a problem--but if their to tight-- What i had heard and kinda wanted a step by step was: To warm up motor, loosen a rocker back it off till it clatters tighten after it stops clattering about a quarter turn--tighten again. Is that basically it?? Never done it before, so thats why i was wanting to make sure i understood--Thanks
oldschool
Feb 9, 2016 09:21 PM
Speeds8erM-1
Jul 18, 2002 11:36 PM
