Adjustable roller rockers?
Old May 8, 2004 | 09:00 PM
"White Knight"'s Avatar
I have seen adjustable roller rockers and am wondering what they are--or in other words what is the advantage of them. Are they worth it on a high hp motor?
Old May 8, 2004 | 09:01 PM
O yea and should i go with the 7/16" studs? They just bolt in or what kindof modification to install them is there?
Old May 8, 2004 | 09:06 PM
What would a 1.7 ratio do? or is that too much?
Old May 8, 2004 | 09:11 PM
O yea and can i use stock springs? Sorry so many posts......i keep seeing things as i search
Old May 8, 2004 | 09:17 PM
BPS's Avatar
BPS
Keep searching and you'll find all the answers too
1.7 would increase lift over then 1.5 stockers
you will need likley new springs
for 7/16 RR you would need new studs - stockers are 3/8"s they just screw in.
Old May 9, 2004 | 06:00 PM
I know the stock ones are 5/8's but how do you use the 7/16 without machining?
Old May 9, 2004 | 06:27 PM
Mtrhds94Z's Avatar
Both stud sizes have 7/16th threads into the heads.. it's the UPPER [where the rocker goes onto] that are either 3/8" or 7/16" so they just screw out and the new ones screw into the same sized threaded holes in the head...
realistyc
Jul 28, 2015 07:32 PM
JCSWS6
Jul 19, 2015 06:47 PM
9t4lt4z28
Parts Wanted
Jul 19, 2015 06:16 PM
Z28amustangklr
Jul 18, 2015 11:05 AM
