Adjust rockers using TDC method or let the car run?
Old Jul 6, 2004 | 09:48 PM
Showme's Avatar
Hey fellas,
Will adjusting the rockers with the engine running after a cam install have any adverse affects (I know a little oil will be slung everywhere) or would adjusting the rockers using the TDC be the better way.
Does it really matter? I just want my rockers to be adjusted correctly.
Thanks,
Tim
Old Jul 7, 2004 | 12:23 AM
1racerdude's Avatar
Either way is fine.If you haven't learned the "feel"of the pushrod to find zero,running would be better(except for the mess).You will have to get them somewhat close to crank it.Do put the valve cover on the side you are not adjusting.
Back off each one until it tap's pull it down until it barely quit's tapping then a quarter turn.The car may shake or run rough for a minute until the lifter relieves itself,thats OK.After it smoothes out go to the next one---same thing 16 times.
Install covers,gunk engine,and clean up floor--Been there.
Old Jul 7, 2004 | 08:11 AM
RealQuick's Avatar
In all reality you need to do the TDC anyway so you can fire the car. I would just leave the valve covers off and readjust while running as well. Thats what i do. Allow the engine to warm up. What lifters? If comp r's, be sure to tighten right at zero lash. If not comp r's, 1/4-1/2 turn is the usual.
Old Jul 7, 2004 | 08:16 AM
grygst76's Avatar
Definitely use the TDC method if you took the valvetrain apart.....I just destroyed 14 of my pushrods immediately following the valve spring change by thinking the pushrods were tight enough and fired it up, then every rocker came off and proceeded to bend my rods
Old Jul 7, 2004 | 09:16 AM
)2overt SS's Avatar
I did it the TDC way.. I was thinking about doing it with the engine running, but I've never done it that way before. So it just seemed I had too many uncertainties about it. Plus I didn't feel like cleaning up the oil
Old Jul 7, 2004 | 09:19 AM
WS Sick's Avatar
I like the TDC method, but I do each cylender seperately just to be sure that each is closed completely.
Old Jul 7, 2004 | 09:48 AM
RealQuick's Avatar
It doesnt make that much of a mess. If you throw revs it spits oil, but at idle it doesnt spit too much at all. What you do is back the locks almost all the way out so they dont get in the way when turning the nut. As the car runs loosen one nut until the rocker starts clacking and getting real loud (getting real loose). Then slowly tighten the nut up with your fingers until the clacking goes away. That is "supposedly" zero lash. Then do your 1/4-1/2 for non comp R's lifters. Then lockem down. Do one at a time.
Old Jul 7, 2004 | 11:12 PM
Showme's Avatar
Thanks fellas,
I've got the Comp R lifters. And the cam will be a LE2.
Tim
ro2207
Dec 4, 2014 06:18 PM
thenewkid
Nov 27, 2014 09:41 AM
USAirman93
Nov 24, 2014 03:37 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
Brent94Z
Mar 21, 2002 04:44 PM
