adjusing valve without oil in the motor
Old Aug 6, 2005 | 10:41 AM
ZMAN Z28's Avatar
I adjusted my valves while doing my rebuild. Should I re-adjust them after I get oil pressure. Just a gut feeling, I think I should. Should I go with my gut?
ZMAN
Old Aug 6, 2005 | 11:19 AM
zlightning's Avatar
Re: adjusing valve without oil in the motor
Well it can't hurt so might as well.
Old Aug 6, 2005 | 02:47 PM
MachinistOne's Avatar
There is no reason to - find zero lash and depending upon who you talk to, tighten down an additional 1/2-full turn. If you set it correctly while building the motor - you should not have to do it again.
Old Aug 6, 2005 | 03:31 PM
ZMAN Z28's Avatar
Cool, thanks. When I set mine. I turn the nut to 4 o'clock. Tighten down the lock snug, then tighten, then it looks like it turns to a 6 o'clock.
ZMAN
Old Aug 7, 2005 | 04:22 PM
arnie's Avatar
It will depend on the lifter and the actual setting you are striving to achieve. Prior experience is also helpful. It does make for a good starting point however.
Old Aug 7, 2005 | 07:31 PM
ZMAN Z28's Avatar
Right on. I've got another ground or 2 to hook up and plug in a few more wires, bolt up the y pipe fill the fluids, reset the valves, bleed the brakes and it should be complete.
ZMAN
Old Aug 9, 2005 | 03:02 PM
sherwinZ28's Avatar
When I did heads and cam I adjusted them once and after a few miles I noticed they started clacking more so I'm guessing once the lifters have oil in them you have to adjust some more...at least that seems to be my case.
Old Aug 9, 2005 | 07:40 PM
Hydraulics are supposed to be set and forget, when you assemble the motor, give the polylocks 3/4 to 1 full turn and you will not have to mess with them again.
Old Aug 9, 2005 | 09:23 PM
95lt1a4's Avatar
is this on 1:5 or 1:6 rockers equally?
Old Aug 9, 2005 | 10:08 PM
What you are doing is establishing pre-load on the lifter - the rocker ratio does not matter.
HectorM52
Jul 30, 2017 11:46 AM
transam_388
Mar 15, 2015 11:53 AM
Jazsun
Dec 29, 2014 12:14 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
