AcDelco plugs
Old Mar 1, 2008 | 07:46 PM
Maroon96's Avatar
AcDelco plugs
hi !
i have some acdelco #19145295 from summit ACF-14
summit says they gap is .708 , the number #19145295 says gap .060
can i use this without any problem ?
my car is in my sig
thx robert
Old Mar 1, 2008 | 07:53 PM
ss.slp.ls1's Avatar
Get a gap gauge and re-gap them. I think they need to be gapped at .4-.5.
Old Mar 1, 2008 | 07:56 PM
mdacton's Avatar
.708 is the reach about how long the threads are......or how far it goes in the head.
Old Mar 1, 2008 | 08:05 PM
Maroon96's Avatar
so can i use it ? i am confused
why did summit take them in the list for my car ?
thx
Old Mar 1, 2008 | 08:15 PM
mdacton's Avatar
yeah you can use them, sticker under the hood tells you the gap...probly .050
Old Mar 1, 2008 | 08:23 PM
ss.slp.ls1's Avatar
Use them, always check the gap, even if they are pre-gapped.
Old Mar 2, 2008 | 09:30 AM
Originally Posted by Maroon96
hi !
You do realize that .708" is close to 3/4". Have you ever seen a spark plug with a 3/4" gap? That should have been a clue right there that either the Summit info is bad, or you might have misinterpreted it.
Originally Posted by ss.slp.ls1
.......... I think they need to be gapped at .4-.5.
Again...... .5 is a 1/2" gap. Have you ever seen a plug with a 1/2" gap? Why provide info if you aren't sure of the answer..... .4-.5 is a huge range, and an incorrect number.
Factory spec is 0.050"
mdacton figured it out. From the Summit catalog:
ACF-14
ACDelco RAPIDFIRE Performance Platinum Spark Plugs
Spark Plug, AC Delco, Platinum, Tapered Seat, 14mm Thread, .708 in. Reach, Projected Tip, Resistor, Each
Old Mar 2, 2008 | 10:43 AM
Pro_built7's Avatar
look on the radiator cover it says spark plug gap .050
i think my plugs were factory with 104k on them, they were rusty and had stock wiring lol. wow
Old Mar 2, 2008 | 01:20 PM
ss.slp.ls1's Avatar
My bad...I meant .04-.05. I said to get a gap gauge, so it should be clear what is needed.
Old Mar 2, 2008 | 02:07 PM
Maroon96's Avatar
ok thx to all ,now i understand ,my fault with the .708 sorry
greets from vienna rob
KYWes
Jun 14, 2022 06:52 AM
sherwinZ28
11
Aug 15, 2015 05:38 PM
350350
14
Aug 11, 2015 12:03 PM
Xiantyl
Jul 21, 2015 05:42 AM
Dark Zeiro
Jul 19, 2015 08:25 AM
