Accusump....any of you have one?
Old Jul 4, 2005 | 12:35 PM
ZBLKHELLRZR's Avatar
Question Accusump....any of you have one?
Just wondering for the high dollar guys if any of you have a accusump installed? I'll be doing my rebuild in the winter and I am getting one but I wanted to know how do you like it? How is the line installed that does the prelube? Are you using the same port where the OP sending unit goes w/ a T-fitting or are you using the the one at the bottom of the blk for you 94+ guys?
Thanks.
Old Jul 4, 2005 | 02:46 PM
MachinistOne's Avatar
Re: Accusump....any of you have one?
I set them up with a remote filter kit, then plumb the feed line into the block adapter. You can set them up with a solenoid switch to come on with key power or with a low-oil pressure activation switch.
Old Jul 4, 2005 | 03:00 PM
Ok. So my dumb question for today is this. How would I go about doing it for a 93? My oil port is at the bottom and the port at the back of the intake is welded shut. Was the remote filter necessary?
