AC line is touching #2 primary
Old Jun 29, 2004 | 01:24 PM
94NDTA's Avatar
Is this ok? I tried bending it out of the way, but it wouldn't budge. Any suggestions, or will this not harm anything. They are jet-hot long tubes by the way.
Old Jun 29, 2004 | 01:58 PM
krispy's Avatar
just remove your a/c
there should be a little bit of play in the A/C line that goes from the firewall down to the A/C comp. (one I think yourtalking about)
I would put a zip tie around it and perhaps the other A/C line and tighting it as to try to move it off the primary a lil
as to if it will hurt it or not I have no idea
Old Jun 29, 2004 | 02:07 PM
transram97's Avatar
i had the same problem with my jet hots. take a long open ended wrench and put it on the line, get a hammer and knock it out of the way. i put a shirt in between the wrench and the line so i would not harm it. it's not touching my headers and my ac still works.
Old Jun 29, 2004 | 02:22 PM
94NDTA's Avatar
Old Jun 29, 2004 | 09:28 PM
94NDTA's Avatar
I moved it. There is now roughly .14" between the primary and the AC line....Is this enough?
Old Jun 29, 2004 | 09:39 PM
IrocSS85's Avatar
no, I bent mine about 1" away. I used the butt end of a hammer, and tapped it down. the handle end, not the business end. the line will flex quite a bit since its soft alum.
Old Jun 29, 2004 | 10:21 PM
94NDTA's Avatar
Thats what I have been doing...exactly. I guess I need to do it some more.
Old Jun 29, 2004 | 11:35 PM
transram97's Avatar
mine is still real close, as long as it is not touching it should be ok. i didn't want to go to crazy with the hammer.
Knightscrapper
Feb 4, 2016 10:25 AM
blmw
Jun 14, 2015 05:20 PM
4586
Apr 27, 2015 06:08 AM
