AC delete pulley question
Old Jan 31, 2009 | 09:17 PM
97 green ta's Avatar
Today i install my ac delete pulley that i had laying around for sometime. I start my car on and went to check the pulley and the belt came out just a little bit out the pulley, its like i need to install some washers to bring the pulley out .I dont understand is a gm pulley that i bought out of summitracing and the belt fits perfect.Anyone had the same problem?is it commmon or should i buy another one?
Old Feb 1, 2009 | 01:02 AM
93FIRETURD's Avatar
definately a common thing had to shim mine too good luck
Old Feb 1, 2009 | 07:31 AM
OneShoe50's Avatar
Yep, I had to add 2, 3/8" flat washers between the bracket and the delete pulley.
Old Feb 1, 2009 | 09:29 AM
Thank's for your help.
Old Feb 1, 2009 | 02:55 PM
a walker's Avatar
The pulley I bought from Auto Zone came with a spacer to use in this case, which I had to do.
Old Apr 23, 2009 | 06:58 PM
z28 justin's Avatar
Did you guys add the washers between the actual pulley or the 3 bolts holding the pulley to the engine?
Old Apr 25, 2009 | 10:28 PM
SSTAT's Avatar
Had to shim mine too. Put the washers on the three mounting bolts.
Old Jul 3, 2009 | 12:26 AM
Dnsean's Avatar
yea put them on the bolts, 2 per bolt on the back end of the delete bracket.. my headlights brightened up when i ran car with out condensor lol! mine i got from napa and didnt come with washers or bolts, and had to drill out the threading on bracket dunno why it was threaded
Old Aug 28, 2009 | 02:30 PM
DirtyDaveW's Avatar
Where did you guys buy your LT1 A/C pulley delete?
My A/C quit working this past year and I'm going to have to replace the A/C compressor, condensor, dryer, etc next year anyway. Might as well have all that crap out of the way for now.
Thanks!
RUENUF
Mar 13, 2016 03:39 PM
Jason Short
Jan 19, 2015 06:34 PM
cmdeshon
Dec 27, 2014 10:06 AM
rje
Sep 9, 2002 12:35 PM
JetLag
Jul 31, 2002 11:42 AM
