AC compressor install
Old May 13, 2015 | 09:45 PM
plz28's Avatar
I installed an lt1 in a 69 camaro. It came from a 94 Roadmaster. Did not plan to have AC then but do now. accessory drive came from 94. Putting compressor on appears to be a problem because of crossmember. Is there any body out there that has done this successfully?
Old May 13, 2015 | 10:29 PM
Re: AC compressor install
Are you using the accessory bracket from the B-Body? If so, have you checked the F-Body or Y-Body brackets to see if one of them might work better?
Old May 14, 2015 | 09:28 AM
There is some good information midway down this page from Nook and Tranny. The F and B bodies use the same configuration. The Y body moves everything up and to the driver's side. That would probably solve your frame conflict issues.
Nov 18, 2023 07:21 PM
99TransAmWS6
Feb 12, 2015 07:23 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
Snoman73
Nov 17, 2014 07:22 PM
Bill'sWS6
Jul 19, 2002 01:08 PM
