ABS -Non ABS rear
Old Nov 3, 2004 | 12:03 PM
StumpDeisel's Avatar
ABS -Non ABS rear
I have an ABS/traction control rear in my 97 Z, and am looking at a non-ABS rear with taller gears. Can the ABS items be moved to the new rear or do I need to stick with an ABS-equipped rear?
Old Nov 4, 2004 | 05:28 PM
Re: ABS -Non ABS rear
TTT, anyone?
Old Nov 4, 2004 | 05:31 PM
Z95m6's Avatar
What is the new rear end? more than like you can't just install ABS on the new rearend. Although since you have traction control i do believe you can get ABS sensors welded in on the axle tubes then get reluctor rings made to fit the axles of your new rear. Not really something easy to do.
Old Nov 4, 2004 | 05:45 PM
Thanks, that's what I was starting to believe, a good price on an no-abs rear not worth it...
Old Nov 4, 2004 | 05:48 PM
Z95m6's Avatar
It would have to be a great deal on a 9inch or 12 bolt to make it worth rigging up an ABS setup on it.
1996LT1Z28
Apr 14, 2015 07:15 PM
jj_burchiel
Mar 21, 2015 12:51 AM
squarehead
Jan 15, 2015 07:02 PM
ddr698
Jan 9, 2015 10:05 AM
