abs light?
Old Jul 27, 2003 | 05:39 PM
harley883's Avatar
abs light?
my abs inoperative light is on what do you all think it could be ive changed my bulbs still coming on,it goes on and off whats the deal?
Old Jul 27, 2003 | 06:25 PM
Pandamonkey's Avatar
It's possible that your abs my actually be inoperative.
Old Jul 28, 2003 | 05:21 AM
slopokrodrigez's Avatar
Got to get the code. Once you have that, you can check the circuits in question. Once you do that you can find the bad guy. Mine turned out to be a faulty EBCM. Which I got at a local wrecking yard for $25.00. The code is the key.
Old Jul 28, 2003 | 05:34 AM
frmula1's Avatar
From: Somewhere between a shotgun barrel, and a blood spatter on the wall.
get er' up to 90mph... down a steep hill... and stand on the brake for all your worth...
that should tell you in the abs is working or not...
its quite fun too
tho, its hell on rotors, tires, loose cd's in the passenger compartment, your neck, noise polution, gas milage....
Old Jul 28, 2003 | 07:01 AM
moparman's Avatar
If you have a plug wire run close to a brake line, that can cause it.
1996LT1Z28
Apr 14, 2015 07:15 PM
jj_burchiel
Mar 21, 2015 12:51 AM
dluna333
15
Mar 13, 2015 12:30 PM
squarehead
Jan 15, 2015 07:02 PM
