ABS INOP and Security Light
Old Aug 1, 2006 | 11:29 AM
redington's Avatar
prob - ABS INOP and security light has come A couple times. First time just the light. Second time the rpm guage was acting up and when i would go to stop (M6) rpm would drop 500 rpm and you couldnt hear the motor. Half the time it sounded like it wasnt on untill i gave it gas Last night it did it again.
I was driving down the road and the radio was on and it cut out you couldnt hear the car anymore so i coasted over to a side street and pushed on the gas and it came back on. Then i drove it to a buddies house and when i left there i tried to start it and it was like my batt. was dead. So i tried again and it started up.
What has been replaced recently - new opti on it in nov then broke the clutch so it had only run for 1 week. Just got the clutch replaced like 3 weeks ago. Also we put on OVC Wires.
any one have a clue?
Mods in sig. 93 m6
Old Aug 1, 2006 | 05:59 PM
OBE1 95Z28's Avatar
Re: ABS INOP and Security Light
Sounds like a loose power connection. Check your battery terminals and the alternator terminal as well as the ground connections to the engine block.
Old Sep 14, 2006 | 02:32 PM
RyanD's Avatar
did you ever figure out the problem?
Old Sep 14, 2006 | 07:44 PM
ryan woods's Avatar
I had similar problems to this and it was a loose connection
Old Sep 15, 2006 | 10:19 PM
RyanD's Avatar
Loose connection where?
Old Sep 16, 2006 | 04:25 PM
OBE1 95Z28's Avatar
Always helps to read the thread I list the connections above.
Old Sep 16, 2006 | 05:27 PM
RyanD's Avatar
Uh, I wasn't asking you, but thanks.
jj_burchiel
Mar 21, 2015 12:51 AM
dluna333
15
Mar 13, 2015 12:30 PM
bfmv13trivium
Jan 14, 2015 09:57 AM
fpete1992
Dec 11, 2014 03:51 PM
Black Sunshine/ 00SS
Aug 24, 2002 03:41 PM
