abs inop light stays on...
Old Oct 26, 2003 | 05:38 PM
19WS6T/A91's Avatar
my abs inop light has decided that it wants to stay on, it did this once before but after shutting the car off and re cranking it went away, this time i shut it off and cranked it about 4 times and its still there, what causes this?
Old Oct 26, 2003 | 05:42 PM
crAzy95z28's Avatar
hmm...when you went to recrank it did you pull the key all the way out? cause my oil light is doing the same thing, what i did was stick the key in turn the ignition on then turn it back off and take the key out then turn it on and the light goies away...i think it maybe be a fuse or a sensor!! youll have more replies...they shoudl tell ya...ask shoebox he is LT1 GOD!!
Old Oct 26, 2003 | 05:50 PM
Z95m6's Avatar
sounds like your low oil sensor is out. Mine went out and when you would start the car the light would come on, but if you shut it off and restarted it the light would stay out. i put a resistor in sensor to keep the light off until i pulled the motor then i put a new one in.
Old Oct 26, 2003 | 06:14 PM
95 Z/28 LT1's Avatar
Super Moderator
I have heard that if your 3rd brake light bulb burns out it will cause the ABS Inop light to come on. It's worth checking.
Old Oct 26, 2003 | 06:35 PM
Mir Hussain's Avatar
Tech II can be your friend if your car is 96+
Old Oct 26, 2003 | 06:49 PM
SSnakeEater's Avatar
9 times out of 10 when the ABS inop light comes on in a 4th gen f-body it means the abs pump is bad. get it diagnosed
Old Oct 26, 2003 | 07:07 PM
Seal's Avatar
same exact thing happened to me, and i said, well lemme change the oil, and see if it helps...
come to see the plastic holding things broke off, and the sensor was hanging... so it wasnt plugged in, so happy for an easy fix
jj_burchiel
Mar 21, 2015 12:51 AM
dluna333
15
Mar 13, 2015 12:30 PM
eazyZ
Mar 1, 2015 07:12 AM
STR FTR 1
3rd Gen / L98 Engine Tech
Feb 10, 2015 10:36 PM
bfmv13trivium
Jan 14, 2015 09:57 AM
