ABS INOP light and charging issues
Old Jun 8, 2003 | 04:09 PM
96SilverZ's Avatar
Question ABS INOP light and charging issues
I have a 1996 Z28 M6. The ABS INOP light has been coming on intermittently since I had the engine rebuilt(AIR pump removed also). In March I installed a set of GMPP polished valve covers and had to grind a little of the back of the alternator case so it would fit(I read here that this has been done before). Recently the ABS light is coming on more often and I seem to have charging problems. right after I start the car, the voltage seems ok but after I drive the car for a while it will start to drop and fluctuate, sometimes to almost 12 volts on the gauge. Then today I tried to start the car and the battery was completely dead! When I jumpstarted it, there was a big spark off the negative cable were it was clamped to the frame.
Any ideas on what could cause this and were to start looking?
Matt
Old Jun 8, 2003 | 04:17 PM
I think you already nailed it. Your alternator is not charging properly.
Old Jun 8, 2003 | 06:00 PM
96SilverZ's Avatar
What would cause the battery to completely drain overnight?
Matt
Old Jun 8, 2003 | 08:00 PM
n2oCamaro's Avatar
The car is what's draining the battery. With the alternator not charging, the car has to run strictly off the battery.
Old Jun 10, 2003 | 09:25 PM
96SilverZ's Avatar
I had the alternator tested today and it was fine. This is a shop that only rebuilds starters and alternators. The owner(who I know personally) said it was probably the battery. I'm taking the car to the same shop tomorrow to have it checked out.
Matt
Old Jun 10, 2003 | 10:29 PM
If the battery is not accepting the charge from the alt, then same result-dead. Maybe you have a bad cell.
jj_burchiel
Mar 21, 2015 12:51 AM
dluna333
15
Mar 13, 2015 12:30 PM
squarehead
Jan 15, 2015 07:02 PM
bfmv13trivium
Jan 14, 2015 09:57 AM
ddr698
Jan 9, 2015 10:05 AM
