abs inop after tuneup
Old Nov 24, 2007 | 04:33 PM
a4z28's Avatar
I just got a tuneup today changed wires, plugs, pcv, coil, opti. Fuel filter, 160 tstat. After this the car ran great then all of a sudden the absinop light come on I looked underthe hood to see if anything was moved in the abs system I seen nothing. What do u guys think the problem is.
Old Nov 24, 2007 | 06:02 PM
CheshireCat's Avatar
When the ABS inop light comes on in my Z the first thing I check is the center mounted 3rd brake light in the spoiler. If it's burned out, you'll get an ABS inop light.
Has nothing to do with a tuneup and may not be your problem, but it's worth checking.
Old Nov 24, 2007 | 08:34 PM
a4z28's Avatar
Thanks for the reply will check in to that .
Old Nov 24, 2007 | 11:31 PM
My Iroc Z28's Avatar
Is the red brake light on as well? If it is i would also check the black wire with the white or light grey tracer on the passenger side strut tower. It's a common ground between the two and tends to get loose and causes the light to come on.
Old Nov 25, 2007 | 07:43 PM
slowZ's Avatar
i had a problem with mine once when i had the gm dealership here r&r my engine for me, turned out they zip-tied my plug wires to the brake lines and i guess the rf made by the spark going through them made the light come on, anyway that was my encounter with the abs system and could be other things. good luck
Old Nov 25, 2007 | 09:06 PM
moparman's Avatar
As slowz said, a plug wire to close to an abs line will cause the abs to act funny.
Old Nov 26, 2007 | 06:03 AM
cehan's Avatar
I had a problem with my ABS light coming on intermittently awhile back. It turned out to be a loose ground connection at the ground cluster on the passenger fender well.
Old Nov 26, 2007 | 10:28 AM
Sparkz28ss's Avatar
its happend to me too.... I just bumped the connector on the ABS box.... wiggle it and all was ok
Old Nov 26, 2007 | 11:41 AM
2QUIK6's Avatar
Pass side abs wires pass might close to the exhaust just inside of the shock tower, check there.
I've also had a problem with the harness in the rear must have gotten caught on something and tore the insulation just after the harness plug above the axle. Patched it up and it worked fine.
IndyZman
Oct 22, 2015 02:17 PM
TGGodfrey
Aug 17, 2015 08:43 PM
tnmotown
Aug 10, 2015 11:52 PM
realistyc
Jul 28, 2015 07:32 PM
