Abs Inop
Old Jan 31, 2005 | 03:10 PM
vonmoldy's Avatar
Abs Inop
My ABS INOP came on out of the blue yesterday. What makes this go on?
How Do Fix it? It has never come on before but I did replace my spark plug wires a few days ago. Could it have somthing to do with this?
Old Jan 31, 2005 | 03:25 PM
ShawnMacAnanny's Avatar
Re: Abs Inop
Could be your relay, could be a wheel sensor, could be the ABS pump. Does your ABS still work? If not does your Low Trac light some on when it should activate? I have my ABS relay out and my Low Trac light never comes on. Before i took it out i did. I have a bad ABS pump though.
Old Jan 31, 2005 | 03:37 PM
Re: Abs Inop
Since it came on after your plug wire work, I would bet that you got a plug wire too close to one of the harnesses to the front wheel sensor. Some people that don't route plug wires in the stock locations think that strapping plug wires to those wire harnesses is a convenient fix. The trouble is, the high voltage field emitted by the plug wires interferes with the low level voltage that is used in the sensor circuits.
You can also check the ground lug on the RH shock tower area to be sure that it is clean and tight.
Old Jan 31, 2005 | 10:30 PM
Zachz28's Avatar
Re: Abs Inop
make sure all your brake lights are on
Old Jan 31, 2005 | 10:45 PM
camarokid24's Avatar
Re: Abs Inop
Yeah your 3rd brake light on the spoiler especaily. It will make the abs inop come on untill you get a new bulb.
Old Jan 31, 2005 | 10:46 PM
disco192's Avatar
Re: Abs Inop
Hhmm... that is a good idea. Mine is on and I have mine routed there. Cant remember when mine came on, but it could possibly be the cause.
Old Mar 9, 2005 | 08:24 AM
BoobSter-lt1-z's Avatar
Re: Abs Inop
Same problem here...
Last night..Jumped in the car and drove off and noticed the ABS INOP light was still on...
The brakes feel fine...
I will check the above reccomendations and post the fix.
It looks like I have X-mas tree on the Dash with the following lights on all the
time -
~SECURITY
~ABS INOP
~LOW COOLANT
Old Mar 9, 2005 | 08:33 AM
soontobeGN's Avatar
Re: Abs Inop
Join the club, I have my ABS INOP, BRAKE, Low Coolant, ASR Off, and also my high beam indicator because my right headlight went out like a year ago and I am too lazy to fix it(yet have done new wires twice since), so I unplugged my other headlight and drive with my high beams only. I think I will check my wires also, I may have ziptied one to that harness...DOH!
Old Mar 9, 2005 | 08:37 AM
Re: Abs Inop
You must ANNOY the hell out of people when driving around at night with the
HIGH BEAMS ON....!~
Old Mar 9, 2005 | 08:42 AM
soontobeGN's Avatar
Re: Abs Inop
The high beams arent any brighter than the headlights from what I can tell, and its not like I have 2 sets of lights on, the headlights are off.
Old Mar 13, 2005 | 10:46 AM
Re: Abs Inop
So I asked my supervisor on my way out to check my spoiler brake light when i braked and he said it worked. The same night at a Taco Bell Parking lot I asked my girlfriend to hit the brake pedal while i checked the spoiler brake light and it never came on....PROBLEM SOLVED -THANKS -
Went to Autozone and they didnt have the keypad to check for the # for the
brake light or the book and had the worker at the computer check the # and
he gave me the light bulb and said it was it and i went to my house and removed the brake light cover and OHHH! it is the wrong bulb. I am going to pep boys for this...
Old Mar 13, 2005 | 10:58 AM
Z28WannaB's Avatar
Re: Abs Inop
Thats because they aren't. However they are at a different angle which is why it annoys people, because it blinds them because its pointed at their eyes. As aposed to the low beams which are pointed on the ground.
Ever notice how cars coming at you going over pumps lights seem to get brighter on bumps?
- Z28WannaB
Old Mar 14, 2005 | 08:39 AM
Re: Abs Inop
- Z28WannaB
This is very interesting!....Maybe this is why at I have a lot of people flashing their high beams at me eventhough I am driving with my low beams...maybe
one of my low beams is out of adjustment...but they seem to point to the
ground though .....oh well
Old Mar 14, 2005 | 10:09 AM
wants2race69's Avatar
Re: Abs Inop
im having the same trouble happened as soon as i changed wires also..my dad zip tied one of the wires to the harness....my brakes lock up somewhat easy now no abs kinda sucks sometimes
IndyZman
Oct 22, 2015 02:17 PM
TGGodfrey
Aug 17, 2015 08:43 PM
tnmotown
Aug 10, 2015 11:52 PM
realistyc
Jul 28, 2015 07:32 PM
