Abs Inop.
Old Sep 29, 2003 | 11:34 PM
whitedakota's Avatar
Lightbulb Abs Inop.
all of a sudden this ABS INOP light comes on...what is it/what do you think caused it? i can shut the car off and then start it back and the light will go away for about 1min..then comes on?
steve
Old Sep 29, 2003 | 11:49 PM
Hyperspeed97z28's Avatar
check your 3rd brake light.. common cause most of the time
Old Sep 30, 2003 | 12:31 AM
ninetythreez's Avatar
a
also caused by bad wheel speed sensor on inside of front hubs and 1 on the rear axle. 3 per car.
Old Sep 30, 2003 | 05:40 PM
the third brake light is fine...
when i take off about 25 feet it will come on and stay on?
any other suggestions...im about ready to snip with wire to it!
Old Sep 30, 2003 | 05:44 PM
SkAchilles's Avatar
Re: a
There you go
Old Sep 30, 2003 | 10:24 PM
Z94SLEEPER's Avatar
Question
Well then how do you figure out which sensor is bad????
(Dealer time!!??!!)
Eric
Old Oct 1, 2003 | 03:49 PM
pu12en12g's Avatar
(Dealer time!!??!!)
Eric
Bump... Good question
Old Oct 1, 2003 | 05:01 PM
LimitedEd1LE's Avatar
(Dealer time!!??!!)
Eric
Go to a dealer and have them run the computer to find out what codes you are throwing. They will be able to tell you exactly what sensor is malfunctioning.
Old Oct 1, 2003 | 05:32 PM
Find a friend at a pep boys or even a dealer, have him or her scan it for ya.. When my abs light was on I had my friend at a side shop scan it for me with the snap-on scanner.. Nice tool might I add. Being that it isnt your 3rd brake light, It most likely is a bad wheel sensor then.. have you played with plug wires at all lately?
Old Oct 1, 2003 | 11:40 PM
i had just finished changing the driver side plug wires and the coil wires, just before it started coming on...that was monday night.
tonight, my buddy used his dads snap-on computer thing-a-ma-jig...and it came up being this:
LF WHEEL SENSOR
how to fix that? how much to fix that? and will removal of brake dust fix that?
thanks again,
steve
Old Oct 2, 2003 | 10:28 AM
Z94SLEEPER's Avatar
Well, my third brake light looks to be working and I have not moved any spark plug wires lateley so it must be one of the sensors..... Now just where to go to have this checked out,,,,,hmmmm. I will let you all know what I find out in the next few days...... BUT, I also had heard this lout pop sound from the rear of the car B4 the light came on and the brakes started to grab the rotors,,,,not a good feeling!
Later,
Eric
IndyZman
Oct 22, 2015 02:17 PM
TGGodfrey
Aug 17, 2015 08:43 PM
tnmotown
Aug 10, 2015 11:52 PM
realistyc
Jul 28, 2015 07:32 PM
