? about removing heads
You at least need the coolant level to be below the heads. If not you'll be dumping coolant down the bores and everywhere else
Why not drain the whole system? Engine work is always the perfect time to clean out the coolant system
When I pulled my heads off I had the waterpump off the front of the motor. If I remember correctly almost all of the water was out of the way of the heads. The little bit that did come out was from the very bottom bolts on the heads, meaning the coolant coming out was below the cylinders. If you have the waterpump off just go for it.
