about to get rid of lt1 for good.. please help!
Old Sep 8, 2009 | 12:33 PM
sn8ke eatr's Avatar
Angry about to get rid of lt1 for good.. please help!
first off my car is a 93z28 with a recently built 383.
i started it up broke it in, then removed the heads to change the valve springs. i re- assembled the engine, and it fired right up. there were no problems at this point.
fast foward to today. turn key and crank and its all sporattic and weird. a friend who was watching said that the (GROUND?) strap coming off the driver side head to the frame sparked against a metal brake line touching it.
its all gone downhill since..
now with nothing else changed and jumper cables attached when i turn the key it reads no voltage on the dash, the fuel pump has stopped coming on when i turn on the key, and the starter dosent make so much as a click ( that i can hear anyway) yet i have voltage...
i tried jumping the starter solenoid right to the + terminal on the firewall and nothing still.
i know this is a tough question considerng alot of the wiring has been changed but can anyone point me in the right direction? im about to rip this thing out for a genIII
Old Sep 8, 2009 | 01:03 PM
ulakovic22's Avatar
Have you checked all your fuses? Look under the hood and on the side of the dash and make sure they are all good.
Old Sep 8, 2009 | 01:06 PM
97FormulaWS-6's Avatar
Sounds like you just shorted something out electrical wise. Go through and check all your connections; make sure everything is hooked up properly. Sounds like you blew a main fuse or something similar.
What does having an electrical issue that should be easy to figure out have ANYTHING to do with switching motors completely where you could have the exact same issue if you hook something else up wrong?!?!?!? That's makes absolutly ZERO sense...
Old Sep 8, 2009 | 03:12 PM
meissen's Avatar
I think you need to give me your 383...
Seriously - fuses, connections, etc. You either blew a fuse or shorted/fried something out electrical. No sense in selling to get an LS1 - same mistake can be made with that.
Old Sep 8, 2009 | 03:16 PM
If you have battery/ground/connection issues, a different engine is not going to fix it. If you can't jump the starter right on the solenoid, you have no power or your starter is fried. Do the headlights even come on?
Old Sep 8, 2009 | 03:33 PM
sn8ke eatr's Avatar
is there any explanation for a ground strap sparking to a brake line?
can someone guide me as to which connections could have fried, the fuses are all ok, im not really sure where else to look besides the strap that sparked which is fine, starter wires are fine
is there any way to bench test my starter at home to make sure its functioning properly? i have a funny feeling i fried it and im way overthinking the problem
Old Sep 8, 2009 | 03:48 PM
sn8ke eatr's Avatar
well with a big beatiful [EDITED] from the lt1 gods,
as i was leaning over my engine thinking about it not runnin my wrist bumped into what was a loose main negative ground to the body.
she runs yet again, thank you all for the suggestions, i should know better lol
Old Sep 8, 2009 | 03:55 PM
Wooshie's Avatar
Old Sep 8, 2009 | 04:01 PM
bw_hunter's Avatar
Three hours and fifteen minutes...problem to solution. Not bad...it would have taken me longer even if I was leaning on the wire.
Old Sep 8, 2009 | 08:31 PM
jhthornley's Avatar
yet another reason this site ROCKS
I know it is typical behavior for anyone to question what they just screwed up etc...
but a "reality check" from the folks on here set you straight...
I'm actually selling my '95 Z28, probably never to return (not a big fan of the 5th gen Camaro), but I have really appreciated this site and the generous contributions by the members (Rob and Fred specifically)
Bought a slightly used '07 Cayman S... (was looking at '08 C6 vettes, but found that I could swing the Porsche for similar jack)...
Peace ladies/gents... Again thx for everything.
JT
Old Sep 8, 2009 | 10:53 PM
sn8ke eatr's Avatar
Old Sep 8, 2009 | 11:17 PM
MikeGyver's Avatar
lol, but this is the entire mentality of LS1>LT1 guys.
Sell the LT1 and don't modify your new car.
Old Sep 9, 2009 | 04:26 PM
Venomous360's Avatar
JT
What?? You have a Porsche and now your too good for us?? I think your still welcome here, or am I wrong??
Old Sep 9, 2009 | 06:13 PM
jhthornley's Avatar
haaa
nope... not saying I'm too good for you guys...
just saying that I won't have an "F-body" that needs TLC...
I WILL try to ignore the rustangs that roll past tho...
Old Sep 9, 2009 | 06:14 PM
OneShoe50's Avatar
The best lessons are the ones we teach ourselves, congrats and nice job
