A4 Tranny Lines
Old Nov 19, 2004 | 12:21 AM
Euclid's Avatar
A4 Tranny Lines
What's my best option for replacing my tranny coolant hard lines?
Any suggestions?
Should I get stock replacement pre-bent hard lines from the dealership, some kind of braided line from O'Reilly's, what do I want?
Old Nov 19, 2004 | 01:44 AM
RED95LT1Z28's Avatar
Re: A4 Tranny Lines
Why do you want to replace them? Are you putting a cooler in? If so I used the stock lines and the hose that came with it. Just some hose clamps and done.
Old Nov 19, 2004 | 06:40 AM
30696bird's Avatar
Re: A4 Tranny Lines
I used some metal brake tubing, it worked really well. The reason I hard lined plummed it was because I had a kink in the hose they supplied. I bent it with a pipe bender that I bought from advance auto. The ONLY way I could bend it tight around the radiator was to put sand in the pipe (about 2 inchs from top so it would have space to move when I bent it) and a small propane torch. Heated it, bent it, and flushed it VERY well. Like I say.........worked well for me.
P.S. It looks alot better too.
BigWil
Mar 29, 2015 12:24 PM
jackpawt883
Feb 26, 2015 09:04 PM
737drivr
Feb 20, 2015 11:54 AM
