985 or 978 springs
Old Apr 18, 2005 | 06:15 PM
KENS96M6's Avatar
985 or 978 springs
I will be running a GM847 cam and 1.6 RR therefore near .600 lift. Seat size is not an issue (already enlarged). I know from searches, some people run the 985 springs but no one seems to be running the 978. This spring is between the 985 and the 977 load wise with the same install height as the 985. I plan on reving this motor to 6700+ and I dont want valve float. Also I will be running the Comp. R lifters. Thanks for the imput. Ken
Old Apr 18, 2005 | 08:07 PM
97Z-M6's Avatar
Re: 985 or 978 springs
this is not a advanced thread but look into the kmotion 800s
Old Apr 18, 2005 | 08:54 PM
KENS96M6's Avatar
Moderators can move it if necessary. Thanks for the input.
Old Apr 19, 2005 | 07:40 AM
KENS96M6's Avatar
Someone has to be using these springs. Thanks, Ken
Old Apr 19, 2005 | 08:06 AM
Spinner's Avatar
I have 985s on my car, tons of seat pressure, they hold my cam with .577 lift to almost 7000 without breaking a sweat, setup with a .030 spring seat on each valve and a .015 shim on each each exhaust valve. They should suit an 847 fine I would think.
Old Apr 19, 2005 | 06:14 PM
KENS96M6's Avatar
Thanks Spinner. Anyone else.
Old Apr 19, 2005 | 06:38 PM
vette40th's Avatar
What spring does teh GMPP catolog say to run? That tells you the specs, then find the quality spring that matchces it. The manufacturers put allot of R&D into there valvetrain, I recommend following there advice.
Old Apr 20, 2005 | 07:47 AM
KENS96M6's Avatar
I dont know about GM but the Crane recommended spring for their equivalent cam is a single and I am not sure I want that.
Old Apr 20, 2005 | 11:05 AM
vette40th's Avatar
If this link works, here is there spec requirements. I am sure you already looked at it. http://www.cranecams.com/index.php?s...&lvl=3&prt=122
But if not comfortable, cal Crane and ask them what they recommend. With the Singles, maybe they will recommend a rev kit, or just recommend some duals. Allot of valvetrain companies are going singles nowadays. CompCams just put out a newer beehive that they used ona big Block, and they have had no problems. I am using beehives, but my cam is only 555 max lift , but it is a XE cam which is a little more aggressive on valvetrain due to its design.
But, I do recommend calling crane, they know valvetrains better than us.
95z28man7
N2O Tech
Aug 16, 2015 10:58 AM
9t4lt4z28
Parts Wanted
Jul 19, 2015 06:16 PM
Z28amustangklr
Jul 18, 2015 11:05 AM
Catmaigne
Jul 14, 2015 05:17 PM
