'97 up opti and spark test?!
Old Jun 26, 2003 | 12:53 AM
1997TransAm's Avatar
does the procedure given on this website http://csce.uark.edu/~jgbertr/rb/4th...mpression_test
work for a '97 opti. I'm wondering because the diagram is from a '95 and the wire colors are different. anybody?
Old Jun 26, 2003 | 01:43 AM
ttt
somebody has to know
Old Jun 26, 2003 | 08:16 AM
ttt
Old Jun 26, 2003 | 08:33 AM
I think you posted the wrong link if you are testing the opti.
Is this what you meant? What wires are different? The only thing that I know is different is the wires and connector to the coil (not the ICM), since the later models have a single connector coil. The procedure does not say to test by wire color, but by the cavity designation. Testing should be the same.
Old Jun 26, 2003 | 12:45 PM
it is strange. i keep testing it and i'm getting power on B and C not A and D. they are both around 11.5v. any ideas?
Old Jun 26, 2003 | 01:12 PM
alright here we go. I found this diagram
that shows that A and D are the outer two wires, not inner. It must be different for the '97's. If that is your website shoebox, i would add that in there to avoid further confusion.
Old Jun 26, 2003 | 03:40 PM
Not sure what that link to Toyota stuff has to do with it, but diagrams are frequently drawn in a way to simplify following the wires and readability. You should be looking at the cavity designations that are embossed on the connector to determine which is A-B-C-D. This is the way the connector actually is, so A and D would be on the outside as you say.
Old Jun 26, 2003 | 04:00 PM
woah sorry bout that, the link must have changed, heres the picture
greenzee28
Mar 26, 2015 09:13 AM
naaz90
Jul 27, 2002 08:22 AM
